Old 10-14-2012, 10:44 PM   #1
Lee Mitch
Default top/molding sealer?
The next step on the ground-up restoration of my '30 Briggs fordor is the top. I understand that a sealer of some sort is recommended between the top material and the body, and then again between the top material and the molding. Does anyone have a recommendation on what kind of sealer that should be? Thanks so much.
Lee Mitch is offline   Reply With Quote
Old 10-15-2012, 06:18 AM   #2
jburessr
Default Re: top/molding sealer?
3M makes a glass/weather strip sealer, it's black and you can get the gun to apply it with, it looks like a pump oil can with a long tube so you squirt it into any cracks or openings. Stuff works great!!! little expensive but it's worth it!!!
jburessr is offline   Reply With Quote
Old 10-15-2012, 06:34 AM   #3
2manycars
2manycars's Avatar
A tube of black seam sealer from your auto parts store or body shop supplier will work nicely.
2manycars is offline   Reply With Quote
Old 10-15-2012, 12:37 PM   #4
Al Bass
Al Bass's Avatar
I used 3M 5200 (small tube) around edge of material and over tack heads, it is flat black and takes 7 days to cure but remains plyable, and Ive used it to seal windshield rubber on my 64 pv544
Al Bass is offline   Reply With Quote
Old 10-15-2012, 04:56 PM   #5
ctvpa
ctvpa's Avatar
There is a good video on the model a site that shows step by step top replacement, but they change the base to fiberboard. But I used this http://www.abarnyard.com/workshop/roofinstall-1.htm
ctvpa is offline   Reply With Quote
