10-30-2017, 05:45 AM | #1 |
ID multiplate or single plate clutch
Is there an easy way to tell if a car has a multiplate or single plate clutch before taking the vehicle to pieces??
10-30-2017, 06:25 AM | #2 |
Re: ID multiplate or single plate clutch
Removing the clutch inspextion cover below the floor board would be one.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
10-30-2017, 07:45 AM | #3 |
Nothing external on bell housng then?
10-30-2017, 08:11 AM | #4 |
The only "external" hint, of a multi-disc clutch would be if this is an early car? If so, they used different clutch and brake pedals with a smaller diameter pedal shaft. That, and does it have a left hand parking brake? The multi-disc clutch was only used in the early 28 cars.
Hope this helps. Jeff
Let's let pylons, be pylons! |
10-30-2017, 09:00 AM | #5 |
Multi disc clutches have a different inspection plate on them than single disc cars. The plate is a little smaller and has no louvers on it. I believe it also has non-slotted holes for the retaining screws, unlike the later single disc inspection covers with open slots for the retaining screws. I tried to find a picture of on, but couldn't.
Rusty Nelson |
10-30-2017, 09:57 AM | #6 |
10-30-2017, 10:24 AM | #7 | |
The dead give-away is the inspection cover and the side were the pedal shaft is. The pedal stop for the brake area is different. I'll see if I can come up with some photos.. Dudley |
10-30-2017, 01:44 PM | #8 |
'Get Out & Crawl Under '........
The multi-disc clutch shaft arm is longer than a single disc arm. Some have used the longer arm for more leverage on a single disc clutch. JB |
10-30-2017, 02:15 PM | #9 |
A little fuzzy but it may help, pay no attention to the shift nob!
10-30-2017, 05:18 PM | #10 |
my Nov. 28 coupe has a multi-disk clutch. It is an original, low mile never dis-assembled vehicle. The Judging Standards state that Nov. 28 was the changeover period to the single disk clutch.
10-30-2017, 08:34 PM | #11 | |
The inspection cover is wider than tall on the multiple, and it's taller than wide on the single plate. The AA cover is square. |
10-30-2017, 09:29 PM | #12 |
10-30-2017, 09:34 PM | #13 |
See if this photo loads
10-31-2017, 03:32 AM | #14 |
Thank you everyone.
