05-04-2012, 04:19 PM | #1 |
Another question on hub bolts
Is there any reason you should not heat hub bolts to make it easer to compress them.
Ed |
05-04-2012, 04:38 PM | #2 |
Re: Another question on hub bolts
I did one that way on an original 31 cast iron drum and hub. It worked good for me, just don't quench the hot metal or it will become brittle and break.
05-22-2012, 09:34 PM | #3 |
Anytime you heat a piece of metal,stud bolt, rivet, etc. and work it, it will shrink and become loose. Wheel studs and rivets should be cold formed for a tight fit.
05-22-2012, 09:54 PM | #4 | |
Joe
1929 Tudor since 1962 Feather River A's |
