Old 01-23-2014, 12:49 PM   #1
34hardhead
34hardhead's Avatar
Default 1934 Ford Radio bracket id
I have several of these brackets, and cannot figure out how they fit the
Radio, I think they go behind the radio to the firewall, but do not know for sure, also are they for an ash tray radio or glove box radio,
Attachment 162701
Attachment 162702
Attachment 162703
34hardhead is offline   Reply With Quote
Old 01-23-2014, 12:56 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 1934 Ford Radio bracket id
Your attachments did not come thru for me
Old 01-23-2014, 12:57 PM   #3
Lawson Cox
Lawson Cox's Avatar
Nor me.
Old 01-23-2014, 01:01 PM   #4
34hardhead
34hardhead's Avatar
Can you see these
Old 01-23-2014, 01:53 PM   #5
34ford
34ford's Avatar
that is the rear bracket for the glove box radio
34ford is offline   Reply With Quote
Old 01-26-2014, 10:26 AM   #6
fordbug79
Would you be willing to sell one of the brackets as I am in need of one.
Thanks
fordbug79 is offline   Reply With Quote
Old 01-26-2014, 11:03 AM   #7
Randy
Randy's Avatar
Since no one has mentioned how it fits and that seemed to be part of the original question, here goes: the shouldered stud and the pointed end go to the firewall with the pointed end up, the shouldered stud going through the hole in the firewall (which has to be punched out if the car never had a glove box radio before) with a nut on the outside and the point digging into the firewall insulator (possibly designed to pierce the paint to create a ground, not sure?). The shoulder is there to allow tightening of the bolt without crushing the firewall insulator. The other stud goes through the hole in the bracket on the back of the radio with a nut to support the back of the radio.
Randy is offline   Reply With Quote
Old 01-26-2014, 11:56 AM   #8
Pete/Ct.
If you are selling them I could use one also, thanks. Pete/Ct.
Pete/Ct. is offline   Reply With Quote
Old 01-26-2014, 01:13 PM   #9
DavidG
DavidG's Avatar
I believe you meant to write that the pointed end faces up.
DavidG is online now   Reply With Quote
Old 01-26-2014, 03:10 PM   #10
Randy
Randy's Avatar
Yes, that's correct, sorry. I corrected it above. Thanks!
