01-16-2020, 03:19 PM | #1 |
6 Qts. OF OIL In MY 8BA
Not trying to reopen a question but, I thought it would be worth posting that my 8BA engine with a 1950 Mercury rear sump oil pan and oil filter holds 6 quarts of oil at the full mark on the dip stick.
Dip stick measure 16 1/2 in. from tip to hilt. |
01-16-2020, 04:06 PM | #2 |
Re: 6 Qts. OF OIL In MY 8BA
Is the dipstick marked? I have seen them marked "8CM", 8RT", and "8BA".
01-16-2020, 04:24 PM | #3 |
I had the same engine / pan / stick combo in my '40. 5 quarts registered low on the stick.
On a trip to Colorado, (from Michigan) with the oil filled to the full mark on the dipstick, I was using a quart of oil about every 500 miles. This was with a fresh & sound engine well broken in. On my return trip I let the oil stay at the add mark (about a quart low) & used not a drop of oil for 1200 miles. What I'm saying is - 6 quarts in a flathead is too much oil. If your are just puttin' around town it doesn't matter. But at speed, 60 to 70 mph plus it made a difference. The car was OD equipped to allow these speeds. Last edited by 42merc; 01-16-2020 at 04:35 PM. |
01-16-2020, 05:18 PM | #4 |
The '49-'51 Mercury shop manual does state 6 quarts with a filter, 5 in the pan. I have this pan along with a remote filter on my '32 using 6 quarts with no oil usage issues.
I tested the pan capacity in my solvent tank by tilting the pan about 7 degrees (to match the intake carb mount angle) and filled using a quart container. Five quarts were below the windage tray, while 6 quarts came up even with it. |
01-16-2020, 05:52 PM | #5 |
01-16-2020, 05:58 PM | #6 | |
Capacity of Engine oil (dry) 6 qts. |
01-16-2020, 06:07 PM | #7 |
Not sure if a photo I have here will help, but we check all builds for the correct level before the pan gets installed!
This is a shot of Joe V's pan that we welded the removable bottom closed on, I believe it's a Merc or truck?? Thanks, Gary in N.Y. P.S. This is 5 qts to the full mark, no filter in the program!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
01-16-2020, 06:39 PM | #8 |
Looks like an early Ford truck pan.
Is that little rectangular protrusion at the front an add on? |
01-16-2020, 09:46 PM | #9 | |
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
01-17-2020, 09:25 AM | #10 | |
I fabricated the straps here in-house and spent extra time trying to "lower" the fasteners on the #1 main but could only reach a certain point. That's when Joe decided to "mod" the pan in the front! Thanks, Gary in N.Y. P.S. Here's a couple more shots of the pan/straps being done!
01-18-2020, 01:24 PM | #11 |
A little '50 MERC dip stick and oil pan data.
