Old 06-12-2017, 04:20 PM   #1
dubnutty
dubnutty's Avatar
Default Diamond block fuel pump
Well I picked up this diamond block out of a '31 this guy was hot rodding. It's going in my '29 wagon. I have a question about a fuel pump for this engine. It has a block off plate and the eccentric is there on the cam. Who sells a fuel pump for this engine. I've tried searching on line but still not sure what I'm looking for. Any help in this would be great.
I'd go to the far ends of the earth for a GOOD beer.
dubnutty is offline   Reply With Quote
Old 06-12-2017, 04:23 PM   #2
flatford39
Default Re: Diamond block fuel pump
Isn't that a "B"motor and not an "A".
flatford39 is offline   Reply With Quote
Old 06-12-2017, 04:32 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, it's a diamond B with a cut oil pan for the flywheel cover.
Unless you are using a low tank or a downdraft carb, you shouldn't need a fuel pump.
Old 06-12-2017, 04:33 PM   #4
dubnutty
dubnutty's Avatar
Yes it is.
Old 06-12-2017, 04:34 PM   #5
dubnutty
dubnutty's Avatar
Yes I'm doing both. I don't want to run an electric.
Old 06-12-2017, 04:46 PM   #6
Charlie Stephens
The correct, rebuilt, original pumps carry a crazy price tag ($400?). There must be a repro out there or someone that can rebuild an aftermarket pump. I would start with rennerscorner.com, (734) 428-8424.
Charlie Stephens
Old 06-12-2017, 05:09 PM   #7
BirchRidge
BirchRidge's Avatar
Volvo b20 fuel pump fits right on you just need to modify the pump lever some, sells on e-bay for about $40.. Cheaper and looks almost the same
BirchRidge is offline   Reply With Quote
Old 06-12-2017, 05:11 PM   #8
dubnutty
dubnutty's Avatar
Thanks Charlie!! I try them.
Old 06-12-2017, 05:14 PM   #9
dubnutty
dubnutty's Avatar
Birch, I use to service write at an independent Volvo garage many moons ago. So B20 is a very familiar thing to me. Do you know what kind of modification must be done to pump?
Old 06-12-2017, 05:33 PM   #10
BirchRidge
BirchRidge's Avatar
You need to change the angle on the pump lever a bit, it's a simple cut, bend, weld operation. I don't remember how to post pics but if you Google the pumps you will see the differences
Old 11-14-2017, 07:32 PM   #11
jim1932
jim1932's Avatar
Does it have this crankshaft?
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
