04-11-2018, 07:43 AM | #1 |
LED Headlight Replacement Bulbs
Has anyone tried the LED headlight replacement bulbs offered from
RESTORATION SUPPLY COMPANY 15182 Highland Valley Road Escondido, CA 92025 800-306-7008 760-741-4014 [email protected] are they bright enough so you do not need high beams? their bulb replaces the 32/32 not the 32/50. |
04-11-2018, 04:27 PM | #2 |
Re: LED Headlight Replacement Bulbs
Sounds like a SURE way to get a TICKET to see the JUDGE!
Bill Bright
04-11-2018, 07:56 PM | #3 |
here come the Judge
04-11-2018, 08:43 PM | #4 |
No, I haven't tried them, but going to see the judge is a possibility. The reflectors for filament bulbs are designed so that the parabolic reflectors have a certain focal point that can be controlled and the bright beams can be aimed with a fair amount of precision.
So many people are so danged willing to get maximum bright, ignoring the fact that without aiming the headlight beam, they are actually blinding oncoming drivers. LED lamps do not have the light emitting from the same physical place in the bulb as a filament bulb, so any aiming is sometimes non existent. Maybe the ones being sold by Restoration Supply are aim-able. If so, then great. Some police departments enforce headlight aiming, but sadly I think most cops are too busy these days to pull people over for blinding headlights. This goes for any car, not just model A's. The older I get, the more sensitive my eyes are to excessively bright lights. I think I am not alone in this group. |
04-12-2018, 03:20 PM | #5 |
Bill thank you, this is the information I am looking for, being new to "A ing" I have a lot of questions, a lot answered by past posts. In your experience do you see a worthwhile difference between the 32/32 vs the 32/50 bulb. That is with all components in proper order. Properly aimed and focused do you feel you have enough night driving light at a speed of 45 mph?
04-13-2018, 04:03 AM | #6 |
I have compared the 32/50's to the halogens and like them better. Cheaper and run way cooler and provide the same light. |
04-13-2018, 09:39 AM | #7 |
So we still don't know how the led bulbs are. Be the first to try them and we'll all be grateful. They should work well with original generators where halogens most often need an alternator. By the way, the 32/50 is a measurement of light briteness called candlepower. Lumens is another scale. The 50 is the second filament, the brighter one.
04-13-2018, 09:54 AM | #8 |
Except you can't really compare the two. Candlepower is a measure of the brightest part of the beam of a headlight whereas lumens is a measure of the total amount of light put out by a headlight. Why can't they just make things easy?
04-13-2018, 01:39 PM | #9 | ||
You may have heard some of these terms: Lux, Lumens, Candlepower. Less known terms: Circular candlepower, Candela, Isotropic lumens. They are all units of different properties and thus cannot be directly converted mathematically like you can convert inches to centimeters. The earliest light unit, the 'candle' was replaced with 'circular candlepower', usually incorrectly listed by bulb manufacturers as just 'candlepower'. WRONG! Since no two candles are alike, the only true measure of visible photon production stems from photographic development and WWII research. In 1948 this method was officially dubbed 'Candela'. Today only scientific and technical light sources are rated in candela. Modern lighting is usually rated in 'lumens' which is actually a wavelength biased measure of 'flux intensity'. Of note here, the term 'Lux' is derived from 'flux intensity'. Lumens may be directional and the number will change with spread concentration while the source is constant in 'candela'. The mix of wavelengths in white light, often weight averaged to a color temperature number in degrees Kelvin (K) affects computation of 'Lumens". The same photon flux density from two sources, one red light, one green light, will exhibit lumen rating bias. The green source will have a higher lumen number despite equal photon flux densities. Isotropic lumens (isotropic = nondirectional) are an attempt to quantify a light source in a manner similar to circular candlepower or candela but with some human eye response wavelength bias. Keeping in mind it is inherently impossible to directly convert any of these units to each other, or to units of work or power such as Watts, I offer up the following numbers based on conditional and debatable algorithmic assumptions:
04-16-2018, 08:49 AM | #10 |
Thus endeth the lesson of the day.
Thank you JB
Connoisseur of Rust |
04-17-2018, 05:09 AM | #11 |
i plan on trying some, not sure if they're the same as those though. I'll let you know (Bet they blow after 2 weeks)
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
Thread Tools | |
Display Modes | |
