Old 04-07-2017, 01:09 PM   #21
Seth Swoboda
Seth Swoboda's Avatar
Default Re: New problem!
Originally Posted by JM 35 Sedan View Post
Yeah Seth, LOL, I'm almost old enough to be a member of "The Rat Pack", or in my case maybe that should be "The Pack Rats"
I was just kidding as you well know.
Seth Swoboda is offline   Reply With Quote
Old 04-07-2017, 04:10 PM   #22
jimTN
uIf you have to buy new stuff, 3:78 are the best all around gears unless you are always going up and down steep hills.
jimTN is offline   Reply With Quote
Old 04-07-2017, 04:21 PM   #23
Mac VP
Mac VP's Avatar
The original gear ratios (3.78 and 4.11) were not reproduced, so unless you can find another good used gearset or an NOS set somewhere, you'll have to work with the new gears in the higher ratios. We carry that '34 ring and pinion in 3.54 and 3.25. With the stock engine you would be happier with the 3.54 gearset. We're closed today but call Monday if you decide to order with us.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 04-07-2017, 05:07 PM   #24
Lawrie
Lawrie's Avatar
Just a note .
I have both a 33 fordor and a 34 3w, when the 33 had the original 33 babbit engine it had the 4.11 gears in,it was as smooth as and would run at 60mph no drama,my 34 has a 36 lb engine and 3.54 gears in,its nowhere near as nice at 60 as the 33 was.
Lawrie
Lawrie is offline   Reply With Quote
Old 04-07-2017, 05:29 PM   #25
JSeery
JSeery's Avatar
What are you saying Lawrie, Ford knew what they were doing??
Old 04-07-2017, 05:30 PM   #26
tubman
tubman's Avatar
Originally Posted by Lawrie View Post
Just a note .
Lawrie
Admittedly, I'm no expert on this, but it seems intuitively the opposite of what it should be. Do you have any explanation of why this would be?
tubman is online now   Reply With Quote
Old 04-07-2017, 05:38 PM   #27
alanwoodieman
if you find yourself wanting a 4:11 gear set for a 10 spline drive shaft, I have one from a low mileage 36 that we changed to a 3:78, had to use an adapter to go from 10 splines to 6 splines for the 3:78. the 36 LB engine really likes the 3:78. what number do you have on the speedometer turtle? 18-3:54, 19-3:78, 21-4:11
alanwoodieman is offline   Reply With Quote
Old 04-07-2017, 06:27 PM   #28
Brewsterbuff
Brewsterbuff's Avatar
I would prefer to stay with the 4:11. If you know of a good used or new one for sale, LET ME KNOW. Car is registered for the Keeneland Concours on Lexington KY in July. I hate to pull a rear from another complete running car in desperation.
Brewsterbuff is offline   Reply With Quote
Old 04-07-2017, 06:53 PM   #29
Brewsterbuff
Sounds great. 37 tooth ring gear, 9 tooth pinion, and 10 spline drive shaft. The Brewster has an extended frame and has a steel plate on the bottom and top of the frame rails, that hides the speedometer turtle. The turtle is on the top of the Torque Tube extension so even with the floor boards out it is hidden by the top steel plate. My speedo was pretty close to correct so I assume that it is correct for the 4:11 rear. Sure would like to get together on the phone. Will try to send a private message with my number. Never did that before, hope I can make it work.
Old 04-07-2017, 09:36 PM   #30
JM 35 Sedan
JM 35 Sedan's Avatar
The later 35-48 gears will not work in a 32-34 rear unless some machining is done on the ring and pinion gears. Plus the splined end of the pinion is too long which would require the pinion or the driveshaft to be shortened.
John
Old 04-08-2017, 07:18 AM   #31
Brewsterbuff
Sounds like the '36 is not the best unless I get into machine work. Have a couple of other replies so I guess I need to check them out.
Old 04-08-2017, 07:35 AM   #32
Brewsterbuff
Is there a way to measure and make sure I get the correct one? I will look mine over for stamped part numbers. Didn't look at them that close for numbers. Frame vin # is 181205754. Most all Brewster were built on the 1934 frame but I will try to check the numbers and make sure.
Old 04-14-2017, 08:27 AM   #33
Brewsterbuff
Thanks to everybody who went out of their way to try to help. I found a set in GA and it arrived yesterday, looks good. Hopefully by the end of the weekend I will have it back together and ready for a test drive. Don
Thread Tools
Display Modes
