Old 04-13-2017, 10:55 PM   #1
klicker
klicker's Avatar
Default clam shell
It looks like I need to replace my u joint...
Anyway, I didn't see gaskets in the joint between the two clam shell halves. Is this the case?
klicker is offline   Reply With Quote
Old 04-13-2017, 11:36 PM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: clam shell
Should be two gaskets and a seal in the clam shell assembly that houses the U joint and attaches the torque tube to the back of the transmission. A paper gasket between the clam shell halves and the inner bell, and another of the same paper gasket between the inner bell, and the rear transmission mount, plus a seal of cork, fabric, O ring, or rubber tubing in the groove of the clam shell halves that rides against the belled end of the torque tube. Pictures attached of two types of gasket kits.....
John
Old 04-14-2017, 09:39 AM   #3
klicker
klicker's Avatar
To clarify, I mean where the two outer pieces are bolted together on the sides. I have all the gaskets as you pictured.
