10-13-2019, 07:29 PM | #1 |
Name of fitting?
Hello folks. What is the name of the coolant fitting near the front center of the intake on a 292? (The one that runs to the heater core) Just found mine to be pretty corroded/thin and would like to replace it.
Glenn ‘56 F100 272 Pacific Northwest |
10-13-2019, 07:47 PM | #2 |
Re: Name of fitting?
The one that screws into the intake manifold is called a Heater Control Valve-Vacuum. Part # 18495 I think. This one?
10-13-2019, 07:55 PM | #3 |
No, mine is just a short one in an L shape without the silver thing on top in the picture. It does look like it is screwed into the intake with a square top and the hose fitting coming out the side of that square.
10-13-2019, 08:36 PM | #4 |
This is a generic one I picked up out of a search. These require a control valve either at the heater or in line in the hose. I don’t know what trucks used, or how your’s is set up. I just googled “heater hose fitting”. You can also get them with a petcock style shut off, to close off the heater in the summer. I don’t know either one is the right thread and hose combo, so check that.
https://www.ebay.com/itm/HEATER-HOSE...-/401716861739 |
10-13-2019, 08:55 PM | #5 |
Thanks Mike, I found that one too and ordered it. My heater has a control valve on the hose that goes to the heater core.
10-13-2019, 10:30 PM | #6 |
It is basically the same as the standard "L" shaped elbow, except this one has a shutoff valve on top. |
10-14-2019, 01:41 PM | #7 |
90 degree hose nipple or barb are likely still available from a few sources. The thread size (National Pipe Thread) and the hose size (ID) would be it's reference.
