04-01-2013, 04:20 PM | #21 |
Re: Oil pressure
Wow. Absolutely amazing.
04-01-2013, 05:04 PM | #22 |
Re: Oil pressure
Pre lube it with a pressure tank.Easy to make and fits all engines.Give you guys something to post pictures about instead of an uneducated guess at best.On something that never existed. PS I'm with you 52 Merc."LOL"
R |
04-01-2013, 06:31 PM | #23 |
Re: Oil pressure
I have used an electric in line fuel pump to pump oil in where pressure gauge connects to the engine
04-01-2013, 09:42 PM | #24 |
Re: Oil pressure
I start all mine like Ol Ron. Never a problem.
04-01-2013, 09:47 PM | #25 |
Re: Oil pressure
Is that just when you dont have anything else to help?
Flatheads forever, JD is my name. |
04-01-2013, 10:10 PM | #26 |
Re: Oil pressure
04-02-2013, 01:58 AM | #27 |
Re: Oil pressure
04-02-2013, 04:56 AM | #28 |
Re: Oil pressure
You've all missed one crucial part of the procedure - you have to cross your fingers.
04-02-2013, 05:23 AM | #29 |
Re: Oil pressure
Ol'Ron, Thanks, I like your and the suggestion of packing the pump with vasline.........once I get there I'll post on how it worked out.
04-02-2013, 10:06 AM | #30 |
Re: Oil pressure
Listen to Ron,
04-02-2013, 11:02 AM | #31 |
Re: Oil pressure
I made a pressure tank, like Walt Dupont had once suggested here, to hopefully get some oil circulating to bearings prior to spinning the engine with plugs out. I also pack the oil pump gears with Vasciline to help get the pump going. I was actually able to get a few psi indication on the mechanical gauge by hand turning the engine at the front crank pulley bolt using a 3/4" drive socket, extension and ratchet. Once I saw this slight indication I cranked it with the starter and got a 30-40 psi reading. I know Henry never did all this at the plants on a new engine but when I have lots of $,$$$'s invested in a rebuild, I prefer to make sure I have oil pressure before start up.
04-02-2013, 11:04 AM | #32 |
Re: Oil pressure
Tousche' Ol Ron, why do they make things so complicated ?
04-02-2013, 11:42 PM | #33 |
Re: Oil pressure
Thanks for injecting some sanity into this thread, Ron!
04-03-2013, 05:46 AM | #34 |
Re: Oil pressure
I 'm with ol' Ron, but if you want a simple primer use a garden bug sprayer
filled with oil instead of insecticide. Pump up the pressure, adjust the nozzle to stream and hold it tightly into the plug hole Ron mentioned. Do this until you see oil flowing. On an OHV watch for oil flow at the rocker shaft. |
05-24-2014, 02:52 PM | #35 |
Re: Oil pressure
Hello Ron, I have a 1953 merc flathead . My oil pressure show on dash gage with a new sender as 20 psi. Very worried . No engine knock but I feal unsure of this 20 psi Thanks Dennis
05-24-2014, 04:30 PM | #36 |
Re: Oil pressure
20 psi Drive it like you stole it and report back.
R |
05-24-2014, 09:12 PM | #37 | |
Re: Oil pressure
05-24-2014, 10:12 PM | #38 |
Re: Oil pressure
Not to worry
05-25-2014, 05:08 AM | #39 |
Re: Oil pressure
Here is a picture of the one I made out of a B 81 Mack secondary oil filter.
Over kill Yes but I can use the shop air pressure and I don't need to keep pumping. But the garden sprayer will work Quight well. 100_1060.jpg 100_1061.jpg 100_1062.jpg 100_1063.jpg 100_1064.jpg |
05-25-2014, 08:13 AM | #40 |
Re: Oil pressure
that's what I did !
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
