10-23-2017, 01:46 PM | #1 |
Antifreeze
I know this must be a subject that has been talked about a million times but I'm unsure so I thought I would ask. I put a new radiator in my car will straight water and now that it's getting closer to Winter I need to get a protected. I have heard about distilled water and regular antifreeze or the 50/50 mix what do you all prefer
Sent from my SM-J700T using Tapatalk |
10-23-2017, 01:52 PM | #2 |
Re: Antifreeze
I used the 50/50 mix from menards and it works great.. Good price too when onsale.
10-23-2017, 02:16 PM | #3 |
Re: Antifreeze
I am using the same stuff I use in my family car, a 50/50 mix. Nothing special.
10-23-2017, 02:30 PM | #4 |
Re: Antifreeze
Some kind of anti-corrosion protection is necessary even if antifreeze isn't required, seems to me.
10-23-2017, 03:05 PM | #5 |
Re: Antifreeze
I use cooling fluid made for cast-iron blocks,it can get hotter before boiling as water,keeps the rust out and no anti-freeze needed
It is a pile of shit bit it's my pile of shit |
10-23-2017, 04:31 PM | #6 |
Re: Antifreeze
10-23-2017, 05:13 PM | #7 |
Re: Antifreeze
I use distilled water bought at the grocery store and Prestone yellow concentrate antifreeze. Usually Wallmart has the best price. Use a 50/50 mix.
Yes, you want antifreeze even if the car is not in freezing temps. Last edited by old31; 10-24-2017 at 03:17 AM. |
10-23-2017, 06:09 PM | #8 |
Re: Antifreeze
10-23-2017, 10:33 PM | #9 |
Re: Antifreeze
Some in my club have had problems with antifreeze foaming. I use O'Reilly Conventional Green Antifreeze made for older cars (pre-1980). No problems for me. I do use distilled water to mix 50-50.
10-23-2017, 10:41 PM | #10 |
Re: Antifreeze
Sounds reasonable!
10-23-2017, 11:17 PM | #11 |
Re: Antifreeze
Don't forget to use conventional formula for use in vehicles with brass radiators. Prestone long life in the yellow jug not compatible.
10-23-2017, 11:19 PM | #12 |
Re: Antifreeze
50/50 green/water causes no issues. my car has sat with it in there for 40 years or more. changed occasionally of course. I use the mix your own out of habit
10-25-2017, 04:57 PM | #13 |
Re: Antifreeze
I use a 50/50 mix in the radiator here in the Mississippi heat. I do refill with distilled water because of all the chemicals and minerals in the tap water. We don't get the winter weather most of you folks do.
10-25-2017, 05:24 PM | #14 |
Re: Antifreeze
I bought some marine grade antifreeze because it is biodegradable. At the time I was losing water out the over flow tube and did not want to harm any thing. I will let people know how it goes.
Mike
10-25-2017, 07:27 PM | #15 |
Re: Antifreeze
I keep my Model As in my heated garage when they're not on the road. Be careful with antifreeze. IT WILL REMOVE PAINT.
10-25-2017, 08:46 PM | #16 | |
Re: Antifreeze
10-25-2017, 09:36 PM | #17 |
Re: Antifreeze
There's been discussion elsewhere about the ethylene glycol ( green, etc.) vs. newer propylene glycol based antifreeze. The latter being less toxic and not as corrosive.
Can't remember which is more suitable in brass and aluminum cores. We use the 50/50 all compatible Sierra in the new Brassworks radiators and no noticeable effects so far. |
10-25-2017, 10:15 PM | #18 |
Re: Antifreeze
I use 50/50 SIERRA Brand Coolant,Propolyne Glycol, available at ACE, with distilled water, which resists foaming and, if leaked, is not poisonous to animals.
10-26-2017, 12:42 AM | #19 |
Re: Antifreeze
More information please! This sounds to good.
10-27-2017, 09:23 PM | #20 |
Re: Antifreeze
If you have pets at home or neighbors who let their pets roam, it would be prudent to always use the non toxic antifreeze. A little more expensive but worth the peace of mind.
Glen
'31 Model A Deluxe Roadster '31 Chrysler Model 70 Sedan '88 Pontiac Fiero GT '36 Auburn Boattail Speedster replica |
