10-21-2010, 11:46 AM | #1 |
Heater
SO I have been looking around for a heater so I dont freese my ass off on my 20 mile drive into work this winter. So far I looked at the maniflod heater and they are way to expencive and I hear they dont work so well. The other thing is one of thoughs new liquid heater cores that you run off the cooling system. at $250 or so thats out of my range. So what im thinking is its junk yard time. Ill go salvange a heater core off some old truck or well something and set it up in a wood box that funnels into a hose with electric fans in it, the hose will conect right into my stock heater vent in my floor the small fans will be ones from a computer as they only run about 3volts some 5 volts Ill hang the box under the pasenger side floor bord and have the other end of the box comeing up from under the seat so the heat can return into and reheat even hotter. Has any one done this before and what type of heater core did you use??
10-21-2010, 06:15 PM | #2 |
Re: Heater
A few years ago I drove my old Tudor to work all winter. I rigged a 6v squirrel cage blower on the inside to pull the air over the manifold heater. I had a finned type manifold Autolite. It took about 2 blocks to get hot air. Worked good. Hot water requires a thermostat et. al.
Good luck. |
10-21-2010, 06:53 PM | #3 |
Re: Heater
Check Craigslist for "Model A Ford parts" someone in your area should have a parts pile that will have one in it. The manifold is usualy a couple of bucks,the cover you might find for 10-20 bucks. A Ottwall health heater works good also and its complete.
Both heaters will run you out of the truck in freezing weather. |
10-21-2010, 08:54 PM | #4 |
Re: Heater
If it's for your PU, a manifold heater and a lap blanket (to ward off drafts) should be more than adequate.
10-21-2010, 09:16 PM | #5 |
Re: Heater
Have you spoken to fellow club members about the heat put out by their manifold heaters?
Mine puts out a ton of heat. |
10-21-2010, 10:54 PM | #6 |
Re: Heater
10-22-2010, 09:12 AM | #7 | |
Re: Heater
I drove an A as an only car in the 50's and when it really got cold the manifold heater was just a big hole letting in cold air. |
10-22-2010, 10:00 AM | #8 |
Re: Heater
We have an "Otwell Health Heater" on our '29 Briggs Leatherback and, frankly speaking, I can't see where a hot water heater could do any better...this damned Otwell will run you out of the car!
Of course, you have to cut a hole in the firewall and many don't like to do that. But, even in the '20's and '30's people had to cut the hole if they were going to install a heater...so I say it's "period correct" and don't worry about it. Also, you have to understand how the heater works, and use a piece of rolled-up metal to provide the ducting into the car. I use a piece of rolled-up aluminum flashing that's been cut-to-length and works quite well. Shoot...I've even heard of folks using an old green-bean can...seemed to work well, too. All in all, these are pretty simple heaters that will work with about anything used for a duct. (Without the ducting they're just a hole in the firewall...is that what you did, Jerry...?) Hope this helps. I'd be interested in seeing a photo of any hot water heater installations though...just out of curiosity. Who knows...but someone's hot water heater installation may make me change my mind...I dunno. All I can say is our Otwell works wonderfully for us...but, I'd like to see what others have done. Stay warm...we do quite nicely.
Freddie (Memphis) "...an opinon on everything...an expert on nuthin'..." I'm still doin' the rhumba, Baby...I just can't seem to quit. If momma catches us doin' the rhumba....momma would just pitch a fit. I can't help myself....it's much bigger than me. If I were you I'd hang on to a rhumba man like me...! Last edited by Freddie (Memphis); 10-22-2010 at 10:06 AM. |
10-22-2010, 10:15 AM | #9 |
Re: Heater
I find the old Autolite manifold heater in my pickup works almost too good, If it's really cold out, have the duct door closed, after one or two minutes, open 'er up and with the little deflection plate on the door, you'll have more heat you can stand. Have you tried Bert's in Co.?? I'll bet he'll sell you a complete set up for cheap money. He's a good guy. The water heaters seem good too, but I just wonder about the "lost" footroom in an A.
10-22-2010, 11:34 AM | #10 |
Re: Heater
See my plan is to use to origonal Heater vent thing on the floor were the heat comes in and hang the heater core unit under the pasenger floor board like the battery is And then just have a retrn comeing uo inder the seat. and ill put a vent in the seat paneel or even louve it. ( my seats not origonal its hoput of a horce and buggy and i am in desperat need of A proper one im getting stabed my rusty springs while driveing.
10-22-2010, 05:34 PM | #11 |
Re: Heater
I agree with the floor board scenario & tried it first but I found the water didn't circulate well enough into the heater core so I gave up & put 2 3/4" holes for the hose connections. The heater is invisible until you look below steering wheel level & the rocker is a very small 2 speed switch I put at the very top of the drivers kick panel. I can send a few photos via email if interested, just don't want to clutter up the forum for those that aren't.Joe
10-22-2010, 05:35 PM | #12 |
Re: Heater
Sounds like a great idea, I like the idea of using the battery box! Joe
10-25-2010, 11:43 AM | #13 |
Re: Heater
So i got the heater core out of the junk yard. I acttualy got locked in when they closed and dident know we were in the back. We had to Scale up a front end loader onto the roof of this 50 year old rusty hulk of a buss grab onto the bar that used to have barbed wire on it and swing though a hole in the fence i went first and my buddy passed me all the tools and the heater core then he did it. Not a sole was there so i ended up getting the part for free. Built the box, its about the same size as the battery. Im going to drill to holes on the sides and put two cast iron flanges on it to put my pipeing to and mounted my computer fan on the inside of eather hole one pushing out and one pulling in. my only concern is that idont know how the collent is going to circulate do you know of a small .5" inline pump at all or do you think the coolent will circulate just beouse of the negitve and positive preshure of the coolant system??
10-25-2010, 02:15 PM | #14 |
Re: Heater
Am I the only idiot in the world that would have gone back the next day to pay for the part?
10-26-2010, 07:45 AM | #15 | |
Re: Heater
Glen |
10-26-2010, 08:46 AM | #16 |
Re: Heater
We need more "idiots" like you guys, Bruce and Glen... A lot more...
Freddie (Memphis) "...an opinon on everything...an expert on nuthin'..." I'm still doin' the rhumba, Baby...I just can't seem to quit. If momma catches us doin' the rhumba....momma would just pitch a fit. I can't help myself....it's much bigger than me. If I were you I'd hang on to a rhumba man like me...! |
10-26-2010, 09:23 AM | #17 | |
Re: Heater
10-26-2010, 09:35 AM | #18 |
Re: Heater
Yes, sir...I can see your dilema, Jerry...-10 or -20 is a tad bit colder than I would want to drive our "A" in. I was referring to +20 and up. Ten to twenty below is almost unheard of around these parts. We've seen -10 for a couple of nights in a row every now and then, but nothing like that for any length of time.
Of course...we've also seen temps over 100 for 20+ days in a row, the record being 108 one afternoon. We didn't drive Jippy car then either, by the way... I have a better understanding of your problem now...and don't envy you, my friend. You keep that kinda cold up there...will ya?
10-26-2010, 10:19 AM | #19 | |
Re: Heater
But if I got locked in the dismantler's yard because of the attendant's carelessness and had to climb the fence to get out with a heater core that would have cost...what, $3 at a pick-n-pull?...I would have figured they still owed me. Joe
1929 Tudor since 1962 Feather River A's |
10-26-2010, 10:55 AM | #20 |
Re: Heater
Ya around hear the averige december january day is 2-8 degrees. I called the place to tell them about the incidant and they told me they new we were back there and after dismantaling the entire dash and fire wall they wernt going to kick us out when we were so close but they wernt sticking around and figured weed find our way out. We were the first people sence last year to need a heater core so its not as if they would make any money on it any way. Almost done with the heater started started putting ll the fittings in last night and installed the fisrt fan.
