02-18-2011, 07:11 PM | #1 |
Engine runs worse when spark is advanced
The timing is set by the book, Starts and runs at full retard but doesn't sound retarded. timing light shows 2 1/2 degrees advanced. as I run the spark lever to advance the engine speeds up but is not smooth and the exhaust poops a lot. if I go to full down it runs worst. It did run right before. could it be a condenser?
02-18-2011, 07:18 PM | #2 |
Re: Engine runs worse when spark is advanced
You said it ran good before. Before what? Did you play with the timing and now it doesn't run?
02-18-2011, 07:21 PM | #3 |
If you are doing this at an idle it sounds right.You don't pull the advance down much until you are under way.About halfway when running around,and all the way down when running down the highway.Just a notch or two at idle.More is required as the speed climbs.
02-18-2011, 07:22 PM | #4 |
I didn't say it doesn't run
02-18-2011, 07:54 PM | #5 |
We need more info if you wont help.
Do it just stop running good all by its self Did you you change any parts Did you play with the points when did you play with the timing before or after the pooping out the tail pipe |
02-18-2011, 08:03 PM | #6 |
Stan/Mo. |
02-18-2011, 08:08 PM | #7 |
Sorry BCCHOPIT...Didn't mean to step on your toes. didn't know you posted again.
Stan/Mo. |
02-18-2011, 08:11 PM | #8 |
If the timing is set correctly, as you state, maybe it's somthing worse like the gears skipped a tooth and the cam shaft is mechanically advanced or retarded on the crank too far? I know a timing chain can skip, but will the gears also skip if they are worn? Hope I'm wrong (I usually am).
02-18-2011, 08:17 PM | #9 |
02-18-2011, 08:53 PM | #10 |
What you describe sounds as if the timing is too far advanced to begin with. When you pull the spark lever down for normal advance when driving it may end up as too much. I have seen this problem on cars that had a timing cover from a "B" engine. When the timing was set by the book it was advanced instead of at TDC. When the handle was pulled down it ran erratic. You might varify that the #1 piston is at TDC when you set the timing.
Hopefully you have a timing cover installed for an "A" engine. Tom Endy |
02-18-2011, 08:54 PM | #11 |
When I start my car, and it runs poorly after running good, I check for contaminantes in the carb jets. If the idle jet is restricted, it will run lean. Running lean typically will increase your rpm's, making it sound like it's not fully retarded. As you pull down on the advance, the engine will stumble, worse the more you pull down. The engine may even backfire.
02-18-2011, 09:11 PM | #12 |
thanks tom, I know for sure its an A cover on it now because when I had the engine rebuild a B cover was put on by mistake and it F*** up the engine running too advanced.
02-18-2011, 09:14 PM | #13 |
Sorry I would never talk down to anyone. I am just asking and I hope I didn't miss something but when did it start running poor? If its after the set or adjusted I would go back you might have missed something. I know I have had to go back in the past.
How cold was it when you had your car running. (I see you live in Main)I drove mine to work today and it took a little bit for it to run right |
02-18-2011, 09:14 PM | #14 |
yes it does sound too advanced. maybe the gear did jump a tooth, I am going to check the #1 piston to make sure it's at tdc. the slot in the cap is spot on. I timed it with Marco's timing instructions in hand. Thanks for the good tips
02-18-2011, 09:15 PM | #15 |
He might have a crack in the distributor cap that shorts across to another cylinder when he advances the spark or revs it up ?? Yes/No ??
02-18-2011, 09:22 PM | #16 |
I have a cutaway cap on it to check for that, looks OK
02-18-2011, 09:30 PM | #17 |
do you have any pics of this cutaway cap it sound cool
02-18-2011, 09:57 PM | #18 |
Here's the back story....It ran great when I parked, it next time I tried to start it after a week or so it wouldn't run. I had an electronic ignition on it that seemed to have stopped working ,no spark. After much troubleshooting I couldn't find why no spark or power to the coil. I removed the components and sent them back to be checked, they were returned saying everything was working fine. I then reinstalled everything but still no spark. to see if it was a bad system I remove the electronic components and reinstalled the point system, set the points, timed it and it started right up but now has this running problem. so, it won't run with the electronic system but will with the old point setup but now it runs rough. Yes It's cold here in Maine, thank goodness for a heated garage. good thing it's not touring weather yet, Maybe by then I will have found and fixed it.
02-18-2011, 10:01 PM | #19 |
Bratton's catalog has a picture of the cap under "ignition timing tools"
02-18-2011, 11:54 PM | #20 |
What happens if you take up the slop by turning the cam clockwise until the points JUST CLOSE at TDC?
Then set the timing at that location while at TDC. That eliminates slop, I guess the lazy way. BTW, you DID set the points with the lever at full retard, right? Were it me, I would just try retarding the spark a bit and see if that "fixes" the problem without getting to introspective about WHY it fixed the problem. |
