09-07-2015, 09:35 PM | #1 |
Double venturi
Can a dbl. Venturi carb be run with a single Venturi?
09-08-2015, 12:42 AM | #2 |
Re: Double venturi
I don't know but would guess it could, but might be less efficient. A&L sells the double venturi and I think some other parts houses do also.
09-08-2015, 03:52 AM | #3 |
Re: Double venturi
I've seen an adapter for this, in a story in Secrets long ago. But like Tom says it probably won't be as efficient. But if you really want to...why not?
09-08-2015, 09:02 AM | #4 |
Re: Double venturi
See pages 8 & 9 in Paul Moller's "The Model A Ford Carburetors" book. The main and cap jets are in different places on the double and single carbs, and the jets appear to be shorter in the double venturi carb.
09-08-2015, 11:08 AM | #5 |
Re: Double venturi
There is a later Double venture that was built with a removable secondary well; If someone happens to have a Holley with this feature I would be interested in obtaining one ? Ron |
