Old 09-08-2015, 09:24 AM   #1
john charlton
john charlton's Avatar
Default Oil Pump tip
I know most of you do this but some do not so this is for them !!! When replacing the oil pan hold the pump in place by a suitable cable tie passed through the two adjacent pan bolt holes and around the back of the pump . When the pan is nearly home cut the tie and pull it clear . Some people use a bolt in the little plug hole this is not good as it is tapered and the straight bolt damages the tapered threads in the block . If you do not have a tie long enough use two as the lock end of the tie will not pass through the holes so put a short one through and use the lock end of another tie to secure it.
John in still no weather Suffolk County England .
Old 09-08-2015, 09:35 AM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Oil Pump tip
John,
Someone?? peened over the locating dowel on Vermin, so the pump would stay up.
Bill W. in HOT-DRY California!
"THE ASSISTANT GURU OF STUFF"
Old 09-08-2015, 11:15 AM   #3
CarlG
CarlG's Avatar
Originally Posted by john charlton View Post
... Some people use a bolt in the little plug hole this is not good as it is tapered and the straight bolt damages the tapered threads in the block ...
There are a couple versions of an oil pump retainer that makes use of the tapered threads. I have both of these.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-08-2015, 11:42 AM   #4
hardtimes
hardtimes's Avatar
X2..KISS is what these devices that Carl shows tells you !
However, if caught in a 'pinch', without your favorite tool, knowing other ways to handle a task is useful !
Old 09-08-2015, 11:56 AM   #5
BILL WILLIAMSON
In a pinch, run a 1/8" NPT die, all the way down on a 3/8" SAE bolt & it will screw in with YO' FINGERS! (CHEEP TOO!)
Bill W.
Old 09-08-2015, 03:09 PM   #6
john charlton
I had never seen those tools before maybe they are lurking in the catalogues and I had not noticed them . I have had several motors where the plug hole threads have been damaged by an owner screwing in hard the wrong bolt not realising there was a taper . Cable ties are readily available and cheap and work a treat .
John in dark evening high pressure fine weather on the way Suffolk County England .
