12-27-2017, 10:50 AM | #1 |
Radiator Hoses
What is correct color of hose for early 29 leaving factory? Red or black with red stripe?
12-27-2017, 12:35 PM | #2 |
Re: Radiator Hoses
see attached RG&JS page 3-4 revised 2011
RADIATOR HOSES and HOSE CLIP (HOSE CLAMP) ASSEMBLIES Radiator hoses were either predominantly black with a red longitudinal stripe which was generally installed with the red stripe facing upward or all red (a small percentage of production). The black hose had a coarse spiral wrapping pattern which is quite visible. The pitch (width) of the spiral pattern from the mold varied. The pattern could be in either the right hand or left hand direction. The red hose had a "U" pattern on the edge of the coarse spiral wrapping pattern which is quite visible. None had a Ford script imprint. The two lower hoses were 2-3/4" long. The upper inlet hose was 6-1/4" long in 1928-29 and 8-1/2" long in 1930-31. Beginning in early 1930, a four row, oblong tube radiator was introduced for heavy commercial vehicles which required a 9-1/4" long upper inlet hose. Both radiator inlet upper hose clamps had the screw on the top side of the hose with the head toward the driver's side. On the radiator outlet hose nearest the radiator, the clamps had the screw ~ on the driver's side with the head facing upward. On the radiator outlet hose at the cylinder water inlet casting, the clamps had the screw on the top of the hose with the head facing the driver's side. Original clamps were either dull zinc or cadmium plated and were not stamped with size numbers. The inlet radiator hose clamp assembly round head screws (No. 10-24 x 1-1/4") and outlet clamp screws (No. 10-24 x 1-1/8") were secured with square nuts (1/8" x 3/8") plated to match the radiator hose clamp assembly finish.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
12-27-2017, 01:24 PM | #3 |
Re: Radiator Hoses
Great info! I was just about to head to buy replacements today.
Thank you! ted |
12-27-2017, 08:46 PM | #4 |
Re: Radiator Hoses
