Old 08-25-2014, 08:42 AM   #1
bart40
bart40's Avatar
Default drum-disc master cylinder for 40
I apologise if this is a well beaten horse but I am still confused. I have speedway discs on the front of my project forty. It's a rolling chassis-body off frame. I'm ready to move on with a master cylinder and lines. My question is which cylinder and what pitfalls to avoid. Thanks.
bart40 is offline   Reply With Quote
Old 08-25-2014, 09:00 AM   #2
woodiewagon46
Default Re: drum-disc master cylinder for 40
Two companies that specialize on braking systems are Master Power Brakes, 888-251-2353 and ECI, 860-872-7046, both can answer any of your brake related questions. Remember you must also consider installation of other brake components such as a combination valve, metering valve and residual valves if required.
woodiewagon46 is offline   Reply With Quote
Old 08-25-2014, 09:02 AM   #3
JSeery
JSeery's Avatar
Might have better luck asking a disc brake question on the HAMB. Mustang master cylinders are popular, but so are others. Just make sure it is for disc/drum. Need to know if your MC has internal residual vales or if you need to add them, also a lot depends on the MC mounting location. If you are using Speedway disc brakes why are you not using their recommended MC? Speedway has a lot of information in the catalog on brake setup.
Old 08-25-2014, 09:36 AM   #4
bart40
bart40's Avatar
good points...thanks
Old 08-25-2014, 02:59 PM   #5
Ol' Ron
Ol' Ron's Avatar
was told that the 73 Ford had a master cylinder for a non power disk/drum conversion. I got on from NAPA for the Model A with the disk/drum system and it worked great. Also the pads make a big differance.
