Old 02-03-2018, 07:17 AM   #1
pookie55
pookie55's Avatar
Default model T hand cranks claw's
Is there a difference in hand cranks claw's?..I ask because mine is missing.. I purchased my car not running "with the promise that it run's". the car is a 1923 model T touring with a engine # stamped indicating 1925. (that's if i checked the engine # correctly) i only noticed the the claw was missing when i could not get the hand crank to engage the crank. I'm a rookie at this so all the help i can get is greatly appreciated. P.S. don't worry my ego doesn't bruise easily. I'm learning.
pookie55 is offline   Reply With Quote
Old 02-03-2018, 07:33 AM   #2
39portlander
39portlander's Avatar
Default Re: model T hand cranks claw's
There are a lot of us NU2theT here on Fordbarn, some very good folks will help you out along the way here.
You need a ratchet 3906 that is for all years 1909-27, I'm cleaning up my parts as part of my cam replacement.
Langs has a 390KIT starting crank rebuilding kit I am using it includes crank sleeve/pin/spring and handle spring.
39portlander is offline   Reply With Quote
Old 02-03-2018, 08:00 AM   #3
pookie55
pookie55's Avatar
thanks so much for the response
Old 02-03-2018, 08:10 AM   #4
39portlander
What I forgot to mention and what IS different are the crankshaft pulleys, pin 3040 is for the 3" pulley 1909-16.
3040B is a 3 1/2" starting pin for the larger pulley 1917-27.
Old 02-03-2018, 10:48 AM   #5
pookie55
pookie55's Avatar
thanks for the update
