06-30-2019, 02:44 PM | #1 |
rear spring ID?
there are 12 leafs, 2.250" wide, shackle hole is 1.166", grease fitting on center bolt,
Also, Having hard time finding a rubber type shackle bushing for this size 1.166 " hole .thanks gus.. |
06-30-2019, 04:39 PM | #2 |
Re: rear spring ID?
You didn't mention the make, year, and model. Call C&G (800) 266-0470. Have that info ready. They have what you need.
06-30-2019, 06:25 PM | #3 |
Re: rear spring ID?
It was a Ebay hot rod in a "basket" project .lots of miss matched parts , I think the axcel might be a 37-41 ,but I think that year bushings are 7/8",, this shackle hole is 1.166", thk/u. gus.
06-30-2019, 07:33 PM | #4 |
Re: rear spring ID?
Is there a part # stamped on the spring leafs?
06-30-2019, 07:44 PM | #5 |
Re: rear spring ID?
post-'35, for sure.
06-30-2019, 08:08 PM | #6 |
Re: rear spring ID?
07-02-2019, 01:19 PM | #7 |
Re: rear spring ID?
thanks all for input ,spring is 42 ,and found bushings at C&G , great resource, thanks for your time ,gus..
