09-19-2013, 08:09 PM | #1 |
Engine hoists
This may have been well-covered in previous threads, but I would appreciate the feedback from the folks who have been there on what constitutes a good engine hoisting rig. I have used an a-frame, and a joist, and a number of other OMG arrangements over the years. So far all my fingers are intact (no thanks to some of the dumb things I have done).
I an not getting any younger, and safety is far, far, more important than cost. |
09-19-2013, 09:17 PM | #2 |
Re: Engine hoists
I have used many devices as well.....tractor with a front loader, chainfall, come along, etc. Finally bought a cherry picker (old, used) which I like best, my only advise on those is buy or borrow a GOOD one! The cheap imported ones are scary.
09-20-2013, 08:24 AM | #3 |
Re: Engine hoists
Lots of questions first:
If your a "shade tree" mechanic then a big enough tree works fine. If your working on a concrete floor then an engine jack that moves is better than moving the car. If you put a couple of 2 x 6's across the garage (assuming a 1 car garage), then a come-along or chainfall works OK. I've even dropped an engine out the bottom, onto a creeper, and rolled it out. If you buy a commercil engine jack, don't go cheap! |
09-20-2013, 09:17 AM | #4 |
Re: Engine hoists
I use a hydrualic with a adjustable tilt that works just fine. Check the wall thickness of the tubing on these, you will see differences - why some cost $125 and others
are more $$. I prefer this to the chain fall I've used as I can move this hoist around as required to move the engine.
Henry Ford designed the flathead without the aid of a computer. |
09-20-2013, 10:27 AM | #5 | |
Re: Engine hoists
09-20-2013, 10:32 AM | #6 |
Re: Engine hoists
Charlie Stephens |
09-20-2013, 10:42 AM | #7 |
Re: Engine hoists
U-Steal-em engine hoist works well. Buy a good one, heavy with long legs (hoist...not). One that can be dis-assembled for storage works beat for me. Years ago I built engines in the attic of "pops" garage and then lowered thru trap door into my hot-rod! I wish I could "do it again"!!
09-20-2013, 10:54 AM | #8 |
Re: Engine hoists
And while you're buying your cherry picker (the only way to do this in a civilized manner), also buy an adjustable balance lifting rig to be able to adjust the center of gravity. You'll thank yourself when you try to change the angle of the engine as it is coming out.
09-20-2013, 11:01 AM | #9 |
Re: Engine hoists
Be careful of where you get the adjustable tilt rig. There was a thread on the hamb of cheap ones binding and also some experienced the chains breaking. Mines a cheaper one and it binds some, I changed the chains but I need to replace it completely.
I bought a good used 3 ton cherry picker from a family member for car engines and have a few chain falls for other heavy stuff. Good chains are a must and you can back up the chains with a couple of heavy ratchet straps. Better safe then sorry. |
09-20-2013, 11:12 AM | #10 |
Re: Engine hoists
Here's the link to one of the threads on the bad engine tilt or leveler.
http://www.jalopyjournal.com/forum/s...d.php?t=308335 |
09-20-2013, 12:46 PM | #11 |
Re: Engine hoists
When I was young and dumb and full of s###, I used a chainfall over a 2x4 roof member to pull a 49 flatty, and luckily survived to pull a 4banger. The 2x4 was cracked, but held somehow, then I got even luckier when my chainfall was stolen!
Alan |
09-20-2013, 01:37 PM | #12 |
Re: Engine hoists
I would be leery of using tree branches and wooden beams to hoist engines. A cherry picker with a good engine balancer will be best. Whatever you pay it will still be cheaper than a band aid in the emergency room.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
09-20-2013, 03:03 PM | #13 | |
Re: Engine hoists
09-20-2013, 04:20 PM | #14 |
Re: Engine hoists
The best one I have used had all four "legs" adjustable for length.
If I could find one like it I would buy it in a minute. It was a buddy's and he got it from Harbor Freight but they don't have that model any longer (this was 15 years or so ago). You could get the front legs well beyond the pick point (hook) and extending the rear legs out gave great stability side-to-side. It was not collapsible, so it took up a lot of room. It only took a few minutes to disassemble it though if you needed the space. |
09-21-2013, 12:33 PM | #15 |
Re: Engine hoists
Used to use an A frame from a kid's 2 swing set and a "borrowed" chain fall (which I just got back from the borrower after 50 years. Worked great, was usually at a different home garage each week-end.
Paul in CT |
