08-20-2019, 06:51 PM | #1 |
56 window trim
I need new clips for the rear window side trim on a 56 fairlane dose anyone know where I can buy the new clips.
08-21-2019, 09:50 PM | #2 |
Re: 56 window trim
The way it is installed is you tuck the bottom lip of the short piece under the bottom window trim and lay the short piece flat against the rubber and snap the top into place over the top window trim piece. You might need to tweek the top piece where it goes around the bend a little so it will catch real good on the top window trim piece. All it needs to stay in place is a little tension at the top around that top window trim piece and the bottom can't come out because it is tucked under the bottom window trim piece. Never had one fall off on the road in more than 40 yrs driving the p**s out of this '55. |
