Old 07-28-2019, 05:18 PM   #1
olddragracer
Default Replacement Ignition Key
Is there a way to get a replacement ignition key for a 1940 Ford column ignition switch by providing the cylinder number? I have removed the cylinder but I don't have a key. I can find replacement blanks but no cut keys. The number on the cylinder is "FK 402". Thanks
olddragracer is offline   Reply With Quote
Old 07-28-2019, 05:47 PM   #2
meric42
meric42's Avatar
Default Re: Replacement Ignition Key
Any good locksmith should be able to cut a new key from that code
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 07-28-2019, 06:17 PM   #3
oldford2
oldford2's Avatar
pm 32phil
A great ford locksmith. He will send you his phone # and talk to you.
A real Ford guy
John
oldford2 is offline   Reply With Quote
Old 07-29-2019, 06:51 AM   #4
corvette8n
corvette8n's Avatar
https://www.fordbarn.com/forum/showthread.php?t=46583
Phil cut mine from the door cylinder code, works great.
Old 07-29-2019, 07:23 AM   #5
Terry,OH
Terry,OH's Avatar
Just be aware if you have not used the lock cylinder in the past, a new key may not work due to unseen problems with the cylinder. a new key is worth a try. Also spray a cleaner in the cylinder and then a light lubricant (not WD-40).
Old 07-29-2019, 07:59 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
Keys can be cut to a cylinder number, but there is no guarantee it will work in that cylinder now because the pins in the cylinder wear over time. However, it's still worth a try, and if it will not open the cylinder, you can have the cylinder pins changed to fit the key.
EDIT: I started this post before Terry posted, and got sidetracked with something else, them came back and posted, so I am sorta repeating some of the same things he said.
PS....Originally, the ignition lock cylinder and passenger door lock cylinder are usually keyed the same. On my 35 avatar, I could not get the ignition key to work in the door, so I removed the door lock cylinder and had a locksmith make a new key to the numbers on that cylinder and it did not work. So we sprayed some sort of cleaner into the key opening and gently worked the key in and out, and side to side in the cylinder, and the lock began working intermittently at first. The more I worked with it, the better it got.
John
Old 07-29-2019, 09:36 AM   #7
Charlie Stephens
If you added your general location someone might recommend a good locksmith around the corner.
Charlie Stephens
Old 07-29-2019, 09:54 AM   #8
DavidG
DavidG's Avatar
32Phil is the man for the job.
Old 07-29-2019, 01:23 PM   #9
32phil
Thank You all for the kind endorsements.
olddragracer you can call me with your info and I will cut your key.
If there is an issue I can help further if necessary
Phil 845 551 5132
Early Ford Lock & Key Service
32phil is offline   Reply With Quote
Old 08-01-2019, 08:55 PM   #10
olddragracer
Thanks everyone for the help. And thanks for the offer Phil. I will give you a call. I am in Texas.
