Old 07-16-2021, 09:26 AM   #1
renobill
Default Clutch Problems
I have a 1930 Victoria, 1947 Flathead, Speedway adapter for a Chevy S-10, T5 transmission. I recently pulled the Transmission to check on a "chatter" in the clutch and found nothing wrong (ie: no fluid or subsatances on the clutch disk, etc. Now I can't get the clutch to engage properly. I have replaced the slave cylinder, adjusted the push rod of the slave, bleed the master clutch cylinder and slave countless times. I can start the car in gear and the clutch seems to work but if I start in neutral and try to shift into any gear, it won't go. If I adjust the push rod to its max and push the car in gear slowly while depressing the clutch it will engage and the car will move but as I continue to depress the clutch it will disengage as the clutch pedal nears the floor. HELP!
renobill is offline   Reply With Quote
Old 07-16-2021, 10:28 AM   #2
nkaminar
nkaminar's Avatar
Default Re: Clutch Problems
I am not the expert on V8 cars, but I would guess that something is dragging in the clutch. Probably the clutch disk. It may be related to the chattering. I know that with a stock Model A clutch, the height of the fingers for the pressure plate have to be set within +/- 0.002 inch. It could be that some dirt or other contaminate is behind the clutch pressure plate causing one part of the pressure plate to be pushing on the clutch disk while the other part is not.
Nice car, by the way.
Old 07-16-2021, 10:33 AM   #3
Ruth
Since it sounds like you have a modern setup with a hydraulic clutch I would suggest you ask your question over on The Ford Barns sister publication, The Jalopy Journal. https://www.jalopyjournal.com/
Ruth
Old 07-16-2021, 10:50 AM   #4
Patrick L.
Patrick L.'s Avatar
Finger or diaphragm pressure plate ? I'm thinking its a diaphragm.
Old 07-16-2021, 06:53 PM   #5
renobill
Its a finger pressure plate.
Old 07-16-2021, 07:20 PM   #6
Patrick L.
Patrick L.'s Avatar
Hmm, thats strange. How much free-play do you have ? It kinda sorta sounds like you don't have any or enough free-play and pushing the fingers too far. Free-play should still be there [ 1-1.5 "] with the finger pressure plate.
Old 07-17-2021, 06:16 PM   #7
nkaminar
nkaminar's Avatar
Bill, Not sure it this will help because it is related to Model A's. But a clutch is a clutch. The "Model A Ford Troubleshooting & Diagnostics" book by Les Andrews lists the possible causes of clutch drag as: Excessive free play, Clutch disk warped, Loose rivets in clutch disk, Bent transmission shaft or tight fit or burred splines or splines covered with gummy oil and dirt, Broken springs in clutch disk, Worn main transmission bearings, Warped bell housing, Warped pressure plate, Grease and oil on clutch facing, Engine not aligned due to broken motor mounts, Loose bell housing on engine.
The recommendations for 11 out of the 12 reasons is to replace things.
Old 07-18-2021, 09:44 PM   #8
daren007
Go back to stock. Problem solved.
daren007 is offline   Reply With Quote
