Old 03-19-2018, 05:26 AM   #1
rer_239
rer_239's Avatar
Default ring and pinion gears + other questions
1. are ring gears interchangable (as long as the same number of teeth are used)?
2. is there special wire that should be used when safety wiring?
3. when safety wiring should washers be added behind castle nuts so the wire
will go thru the slots in the castle nuts?
rer_239 is offline   Reply With Quote
Old 03-19-2018, 05:31 AM   #2
rer_239
rer_239's Avatar
Default Re: ring and pinion gears + other questions
1. are ring gears interchangeable (as long as the tooth count is the same)?
2. is there a special wire to be used when safety wiring (i.e. final ass'y of ring gear and carrier assy)?
3. should washers be added behind the castle nuts so slots in the nuts line up with the holes in the bolts?
Old 03-19-2018, 08:55 AM   #3
1930artdeco
1930artdeco's Avatar
1) Yes they are interchangeable as long as wear is not to bad-in theory. They will eventually wear in together.
2) No, as long as the dia. is correct. Just not galvanized, it loses some strength-at least that is what I have found.
3) Yes, the slots should line up with the holes. That will keep the nuts from backing off.
If I am wrong someone will correct me
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-19-2018, 03:15 PM   #4
Benson
Benson's Avatar
I would not use lock washers inside the differential. Sometimes the lock washers break and then chunks of steel are floating around inside.
Try a different nut in that position OR Grind off some of the mating surface of nut to line up cotter key slots.
Grinding mating surface allows nut to turn a little so it lines up.
Benson is offline   Reply With Quote
Old 03-19-2018, 05:53 PM   #5
davidlee1313
davidlee1313's Avatar
So, the ring gear and the pinion gear are interchangeable? They don't have to be a matched set?
davidlee1313 is offline   Reply With Quote
Old 03-19-2018, 07:17 PM   #6
Patrick L.
Patrick L.'s Avatar
Ideally they should be, but, many a gear has been changed over the decades. They may be a bit noisy.
Old 03-19-2018, 08:47 PM   #7
Synchro909
Synchro909's Avatar
A gear pair weren't made matching, they became that way by lapping them till they were. A pair that have not gone through the matching process might be noisy at first but as they work, they will match themselves and get quieter.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 03-19-2018, 09:33 PM   #8
davidlee1313
Thanks - Patrick L. And Synchro909. I've gat a set that are supposed to come from the same car, but I don't know that for sure. This puts a little more comfortable in using them.
Old 03-20-2018, 03:52 AM   #9
rer_239
rer_239's Avatar
so in the "wearing in process" won't the particles that wear off contaminate the oil and get in the bearings?
Old 03-20-2018, 06:55 AM   #10
Synchro909
Synchro909's Avatar
No more than particles from normal wear will do the same! It is always a good idea to change the oil not long after reinstalling something like a diff anyway. Oh, and I have a magnet on the drain pug to collect metallic particles.
Old 03-20-2018, 07:11 AM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Older Datsuns came with a VERY, VERY fine abrasive in the diff oil, to help lap in the gears. It was MANDATORY that it be changed to REGULAR Gear Oil @ 500 Miles. NO FLUSHING was necessary. We used 140 W. oil. But still used 90W, in the trans.
Bill Quiet
"THE ASSISTANT GURU OF STUFF"
