06-30-2017, 07:12 PM | #1 |
1947 59Ab into model a
Im putting a 1947 59 AB into a 29 model a. Problem I am having is the crank pulley. It is a double pulley and the front pulley is hitting the cross member. I am in mock up so nothing is welded in place. What am I missing? Is there another style of pulley I need? I was going to use a fan mounted generator/alternator which would eliminate the need for the front pulley. Any help is appreciated
Thanks Tom B |
06-30-2017, 09:15 PM | #2 |
Re: 1947 59Ab into model a
The first generation flathead V8's only used one v belt to run water pumps, and fan/generator. Your engine is a second generation V8 with offset water pumps and generator, right? So even if you cut the front pulley off and just ran one v belt, there would be no way to run your water pumps. Or, you could butcher your fire wall to make room, but I wouldn't do that. This gets to be a moral issue, because this forum is for stock Model A's. A first generation V8 would tuck in nicely, or a 60 hp V8 as well.
07-01-2017, 01:30 PM | #3 | |
As said this site is MOSTLY for restoration of As(), so don't take this as brushing you aside, but to get you proper and lots of assistance with you project ! Go over to H.A.M.B. and click on hamb, then click on traditional hot rods. That will take you to tons of knowledgeable guys who have been there and done that ! I'm thinking that you have never done this mod before, so you will ,no doubt, have a number of questions about your installation. Not only are lots of these guys experienced, but willing to share their knowledge. Good luck. Last edited by hardtimes; 07-01-2017 at 01:32 PM. Reason: ............... |
07-01-2017, 02:54 PM | #4 |
Thanks for the help. I will be checking out the HAMB
07-01-2017, 05:30 PM | #5 |
I agree ,introduce yourself at the HAMB. Also the early V8 Fordbarn,many AV8 s there. I would suggest you get the book by Vern Tardel and Mike Bishop,it will answer many questions for you.
https://www.amazon.com/Build-Traditi.../dp/0760309000 John |
07-01-2017, 05:37 PM | #6 |
See you over there , eh ! BTW, only difference between your ride and mine (right now, that is), is that I have a warmed up '32 B engine, not 59AB ! You will most likely end up with what I have...maybe with expensive paint, that is, with '39 top loader; QC rear; dropped axle and Lincoln brake system. Other than that, she could be returned to stock in a days time ! Good luck Last edited by hardtimes; 07-01-2017 at 05:38 PM. Reason: ........ |
07-02-2017, 12:29 PM | #7 |
Thanks. I am looking into the hamb.
07-02-2017, 03:13 PM | #8 |
Did you trim the crossmember like in the bishop/tardel book?
You probably need to use truck pumps and a single belt. |
07-02-2017, 04:46 PM | #9 | |
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
07-07-2017, 03:30 PM | #10 |
Havent trimmed cross member yet. I do have truck water pumps. Also looking int single crank pulley
Thanks for the help |
