Old 07-16-2019, 08:56 AM   #1
NoahVail
Default Will a 390 expansion tank fit a Y-Block?
The coolant expansion tank on my 1961 Y-Block (292 Sunliner) isn't repairable.
Y-Block expansion tanks seem kind of scarce but I'm finding some for Galaxie 390 engines. The Galaxie 390 tanks I'm looking at have the water pump bypass fitting. The radiator hose comes out the passenger side and the bolt holes are horizontal - all same as mine.
Can I use one of these 390 expansion tanks on my Y-Block?
NoahVail is offline   Reply With Quote
Old 07-16-2019, 09:38 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: Will a 390 expansion tank fit a Y-Block?
No. The FYB mounting flange is a different design from the FE.
GOOGLE C1AE 8A080-A and you should come across one.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-16-2019, 09:54 AM   #3
NoahVail
Default Re: Will a 390 expansion tank fit a Y-Block?
The black tank on the right (in your post) looks like a T-Bird FE tank.
The Galaxie 390 tanks I'm looking at have a flange like this.
Old 07-16-2019, 10:28 AM   #4
KULTULZ
KULTULZ's Avatar
Exclamation Re: Will a 390 expansion tank fit a Y-Block?
... hmmph ...
Where did you come across That?
I'll be back.
- WHY IS IT ... -
Old 07-16-2019, 10:44 AM   #5
darrell
that is an y block tank.not from a 390
darrell is offline   Reply With Quote
Old 07-16-2019, 10:58 AM   #6
NoahVail
... hmmph ...Where did you come across hat?
It's listed as a Galaxie Fairlane 390 427 428 Cobra Expansion Overflow Tank.
https://www.ebay.com/itm/61-62-63-64-65-FORD-GALAXIE-FAIRLANE-390-427-428-EXPANSION-OVERFLOW-TANK-COBRA-/143258028150?_trksid=p2047675.m43663.l10137&nordt= true&rt=nc&orig_cvip=true
Same place has another tank listed, that they say only fits early 406s. Sounds like they have some idea of how to tell them apart.
Old 07-16-2019, 11:02 AM   #7
NoahVail
Look like it's the right tank for me but might be mislisted.
Old 07-16-2019, 11:16 AM   #8
KULTULZ
KULTULZ's Avatar
Question Re: Will a 390 expansion tank fit a Y-Block?
Something or somebody is hitting the peyote a little too hard. The one you picture is the FYB pattern, but what would they describe it as a HP FE application (which I never heard of).
BTW. The FORD and BIRD tanks were the same basically.
Can you give me a half hour? I know you are in a hurry.
- WHY IS IT ... -
Old 07-16-2019, 11:33 AM   #9
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Will a 390 expansion tank fit a Y-Block?
Correct.
It was listed incorrectly.
- WHY IS IT ... -
Old 07-16-2019, 12:06 PM   #10
NoahVail
Google returned some references where Y-Block expansion tanks were referenced in discussions of FE engines and in Cobra forums. That had me wondering if Ford was doing some weird crossover applications back then.
In retrospect that wouldn't make sense because (I think) it'd require having a Y-block intake on top of FE heads (not stinking likely).
Old 07-16-2019, 12:21 PM   #11
KULTULZ
KULTULZ's Avatar
Red face Re: Will a 390 expansion tank fit a Y-Block?
Allow me to expound on the statement...
The OP came across the listing and was described as an early FE HI-PO.
Ya' gotta be careful out there, especially as memories and old guys are fading.
- WHY IS IT ... -
Old 07-20-2019, 12:26 AM   #12
slumlord44
I have one. Whats it worth to you?
slumlord44 is offline   Reply With Quote
Old 07-21-2019, 06:39 PM   #13
NoahVail
Not as much because I've bought one (unless my replacement is a dud, then...)
Old 07-27-2019, 11:32 PM   #14
slumlord44
If it doesn't work out let me know. I have no need for it so I'll be reasonable.
Old 07-28-2019, 02:06 AM   #15
KULTULZ
KULTULZ's Avatar
Maybe list it here and/or EvilBay? I guarantee someone is looking for it.
- WHY IS IT ... -
Old 07-28-2019, 08:17 AM   #16
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Swap meet stuff. $10-15 tops.
streetdreams is offline   Reply With Quote
