Old 08-10-2019, 08:48 AM   #1
aandtman
Default Looking for exploded view of 31 locking door handle.
In particular, which end of the plunger that is operated buy the tumbler go up.
It appears it can go either way, but I want to be sure before I assemble everything.
Thanks in advance, Don
aandtman is offline   Reply With Quote
Old 08-10-2019, 10:32 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Looking for exploded view of 31 locking door handle.
are u looking for the cam position?
www.whidbeymodelaclub.com
Old 08-10-2019, 05:27 PM   #3
aandtman
Thanks Gary, that is also helpful, but to be more specific, when you turn the lock with a key, that little nub on the end of the lock clyinder pushes a square pin up and down. The pin is what I am unsure about installing.
Thanks again, Don
Old 08-11-2019, 06:22 AM   #4
kenparker
kenparker's Avatar
How do you get the cylinder out of the handle.?
kenparker is offline   Reply With Quote
Old 08-11-2019, 03:27 PM   #5
Gary WA
Gary WA's Avatar
Read this,thanks to supplier of info. Restorer M/J 1992 pg 32
Old 08-11-2019, 03:45 PM   #6
aandtman
Thanks Gary, I looked in the Restorer Index, but missed that article. Will check again.
Thanks again, Don
Old 08-11-2019, 09:08 PM   #7
jw hash
jw hash's Avatar
that is NOT a 31 handle, it is a 30 or earlier. the 31 have a notch in the face for the release. it is called a removable cylinder. before that you had to take the handle apart to remove the cylinder.
jw hash is offline   Reply With Quote
