03-26-2013, 09:14 PM | #1 |
Stainless Brake lines still leaking on 50 f1
After several attempts to stop leaks, no dice. Talked to tech at Inline Tube, said to keep breaking loose and tighten. Did this till my flare wrench just about had the fitting rounded. So tonight I pulled the leaking tubes off the truck. Some had shavings under the double flare, one had 2 different degree flares on it. One had a sharp edge around the outer flare, which cut a ring around my new front rubber hose fitting. The flares do not look like the same degree as the original fittings. The stainless do not flare out as far as the originals. Inline Tubes are JUNK... These were pre-bent, bolt right on.
03-27-2013, 12:10 AM | #2 |
Re: Stainless Brake lines still leaking on 50 f1
Milt K from Pa |
Thread Tools | |
Display Modes | |
