10-24-2017, 06:10 AM | #1 |
Pressure Plate Adjusting Screws
I am looking for a source for the 6 screws that are staked on a Model A Pressure Plate. I would like to get enough to replace a few sets if possible as we are having a seminar on clutches coming up in November.
Thanks, Jerry |
10-24-2017, 11:10 AM | #2 |
Re: Pressure Plate Adjusting Screws
I think that you could make them on a lathe out of 5/16 NF bolts, there is enough meat in the head to create the tapered part of the bolt. The slot can be cut with a cut off wheel on a high speed grinder, or slitting saw in a mill. I had the dimensions in the shop, can't remember them all now, check the angle of the taper to be sure.
Mark in MT Always looking for another opportunity to be wrong. |
10-24-2017, 12:12 PM | #3 |
I have used Allen bolts coming in from the back and self locking nuts. I have also got stock ones from a clutch rebuild shop.
John |
10-24-2017, 07:49 PM | #4 |
