04-02-2019, 09:39 AM | #1 |
Hard to start
Engine turns over normally but when I PULL the choke out,momentarily, the engine STALLS but SLOWLY continues to turn then FIRES and runs. I have a 6volt battery and did a load test on it and it tested fine. I also did a vacuum test and all indicates normal. I have the same starting problem when the engine is warm on a restart. Could this be a starter problem? Can I test the starter with out removing it from the engine?
04-02-2019, 09:43 AM | #2 |
Re: Hard to start
Sounds like too much advance on start up. Do you have the spark control all the way up when cranking.
04-02-2019, 09:53 AM | #3 |
Re: Hard to start
I forgot to mention I have a B engine with B distributor and B carb. I was thinking about changing the distributor back to a stock A and see if that changes my problem.
04-02-2019, 10:22 AM | #4 |
Re: Hard to start
You might check your static timing and see if it is close to O* or at TDC. If it is advance more that a few degrees you may get kick back. That is the slowing of the starter you are hearing.
04-02-2019, 10:28 AM | #5 |
Re: Hard to start
x2. Retard it a bit and see if that helps.
04-02-2019, 10:32 AM | #6 |
Re: Hard to start
Check before something breaks. |
04-02-2019, 01:09 PM | #7 |
Re: Hard to start
I'm not sure what you mean by 'stalls'. Was the engine running, then shuts down and restarts ? Or does it just slow down or spin slower while cranking ?
The Model B initial timing is 9º advanced over the Model A. Retarding it a few degrees may help. You can also check the draw on the starter motor while cranking [ignition off], that will give an indication of the health of the starter. |
04-02-2019, 08:53 PM | #8 |
Re: Hard to start
Well I feel foolish. Months ago I installed a rebuilt B distributor. Lately I’ve been having a momentary miss, when starting out from a stop. I checked the point gap and sure enough there was very little so I adjusted the point gap and no more miss. Well I forgot my advice to club members that point gap AFECTS TIMING... DUH! Soooo I adjusted the timing and NO MORE STALL while starting. My THANKS to all who set me straight. 👍 😊
04-03-2019, 07:31 AM | #9 |
Re: Hard to start
Thanks for sharing your adventure. It's a good reminder for us all. Chap
04-04-2019, 01:30 AM | #10 |
Re: Hard to start
Well, with an A Model it usually is something basic. At least it was an easy fix.
04-04-2019, 11:00 AM | #11 | |
Re: Hard to start
A good way to check and see if TOO advanced initial timing kick back is the problem . turn the ignition switch OFF and try the starter . If the starter doesn't try to buck and kick back and spins as normal with the switch off ,The timing is the problem . Another thing to consider is that the spark should ALLWAYS be fully retarded when starting the engine . |
