Old 11-17-2010, 01:06 AM   #1
roddyb34
roddyb34's Avatar
Default AA bellhousing
i have found a AA b/h for a conversion but there is no clutch rod or lever ,are they the same as an A type ,
roddyb34 is offline   Reply With Quote
Old 11-17-2010, 01:35 AM   #2
BCCHOPIT
BCCHOPIT's Avatar
Default Re: AA bellhousing
I did not take them apart but but side by side with tape measure it looks the same to me
good luck
Bill
WAC that banger in the A$$ and drive it home hard
http://waccustoms.com
BCCHOPIT is offline   Reply With Quote
Old 11-17-2010, 01:42 AM   #3
roddyb34
roddyb34's Avatar
thanks for that
Old 11-17-2010, 11:08 AM   #4
JtownJoe
JtownJoe's Avatar
Hi, The AA belhousing is about 2-1/2" less deep than the std. A unit but does not have the pedal shaft hole since it was a bracket on the 4 speed AA tranny. I am also doing the conversion to the 4 speed O/D 1987 F-150 Tranny & the pedal shaft must be fabricated into the bellhousing to reposition it in the same location that the original A shaft was. If you e-mail me I can send you the complete instructions & modifacation needed, (COURTESY OF AL, IN NEW YORK) who took the time to document the proceedure, item by item with photos. Good luck, Joe
JtownJoe is offline   Reply With Quote
Old 11-17-2010, 11:38 AM   #5
AL in NY
AL in NY's Avatar
JtownJoe, I just emailed "roddyb34" with those instruction this morning, he had already contacted me......THANKS
AL in NY
AL in NY is offline   Reply With Quote
Old 11-17-2010, 01:20 PM   #6
MAG
MAG's Avatar
Yes, they are the same. The Throw-Out Collar is shorter (2"???) than the A.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 11-17-2010, 03:37 PM   #7
roddyb34
roddyb34's Avatar
thanks for all that ,i will have to try and find a collar ,are V8 ones similar?
Old 11-17-2010, 04:19 PM   #8
JtownJoe
JtownJoe's Avatar
If you are intersted there is a site, you can google for the address, Mac's Speed Equipment in New Zealand that makes a new cast aluminum bell housing with the pedal shaft already in in. It is made to mate the model A to a Tremec F-150 4 speed O/D tranny. It is about $400. plus shipping. Looks like the cats meow! Irt also uses the trannys reg bolt pattern so you don't have to tear down the tranny & drill & tap the casing for bolt holes and also won't have to have front input shaft cut down & front bearing retaner casting turned down to fit the bell housing. Joe
Old 11-29-2010, 12:54 PM   #9
popcorn-guy
popcorn-guy's Avatar
For your convenience.
http://www.macsspeed.com/
popcorn-guy is offline   Reply With Quote
Old 11-29-2010, 06:43 PM   #10
kenparker
kenparker's Avatar
Roddyb34, if you are refering to the shaft that supports the Throwout Fork, yes it is the same as the standard Model A and tne new shafts are available at all Vendors. The lever on the end of that shaft is also the same as standard Model A. The AA Throwout bearing Collars (the thingee that the Throwout bearing is mounted on) are hard to find, BUT, the V-8 one will work and is even a betterchoice. The return spring works better. I have been putting new bushings and a new shaft into one today.
kenparker is offline   Reply With Quote
Old 11-30-2010, 11:44 PM   #11
bgarrett
bgarrett's Avatar
I can verify that Ken Parker knows what he is talking about.
Ken has been a tremendous help to me.
Thanks, Ken!
bgarrett is offline   Reply With Quote
