Old 09-09-2015, 10:09 PM   #1
1955cj5
1955cj5's Avatar
Default How to repair this..?
This repair was made who knows when..it was there when we bought the truck...
I'm sure the best course would be to replace the crossmember...
But, do you think it could be welded, after the patch had been removed?
It is difficult to see how badly cracked it is, but a little is visible...
I guess I'm looking at a "point of no return"...if I remove the patch, would welding be an option?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 09-09-2015, 10:13 PM   #2
Logan
Logan's Avatar
Default Re: How to repair this..?
The best fix is a nicer crossmember. But if you're a good welder or know a good welder, then yes you can successfully weld up cross members
Cowtown A's
Logan is offline   Reply With Quote
Old 09-09-2015, 10:15 PM   #3
daveymc29
daveymc29's Avatar
For a good welder that shouldn't be a problem. The bed should come off and give him room to do it correctly. Also I'd remove the spring so he can replace a good section of your cross member. As you said, a new cross member would be the best fix, and probably the cheapest, unless you have metal working skills and tools, or a good friend that does. JMHO
daveymc29 is offline   Reply With Quote
Old 09-09-2015, 10:31 PM   #4
C26Pinelake
Go for the new crossmember. Likely cheaper and better in the long run! Wayne
C26Pinelake is offline   Reply With Quote
