Go Back   The Ford Barn > The Swap Meet > Wanted > Late V8
Old 10-16-2013, 12:06 AM   #1
56 ford custom
Default WANTED:1956 FORD FORDOMATIC TRANSMISSION/carb/gas pedal linkages and brackets
City: Anywhere
State: Anywhere
I am looking for the complete set of linkages,rods and brackets that connect the gas pedal to the carb then the shifting and kickdown rods. Im not sure if its all the same for the 55 ford car aswell? I need this for a 1956 ford passenger car with a yblock and fordomatic trans.
56 ford custom is offline   Reply With Quote
Old 10-16-2013, 05:19 PM   #2
hooversab
Default Re: WANTED:1956 FORD FORDOMATIC TRANSMISSION/carb/gas pedal linkages and brackets
hi, have everything you need $50.00
hooversab is offline   Reply With Quote
Old 10-18-2013, 09:04 AM   #3
56 ford custom
Back to the top! I think there is something missing from the pic.
Old 10-22-2013, 04:21 PM   #4
56 ford custom
Haven't heard back from the other seller. I'm in need of a complete set.
Old 10-25-2013, 04:39 PM   #5
Daves55Sedan
Daves55Sedan's Avatar
The parts shown in your photo are for a '57.
To make sure you are getting the right stuff, you should indicate which intake manifold your project is for. The bellcranks for the 2bbl manifold are different from the 4bbl manifold. And the 57 bellcrank and passing gear link do not interchange with the '55/56 setup.
Daves55Sedan is offline   Reply With Quote
Old 10-28-2013, 06:03 PM   #6
56 ford custom
Well I am needing a set up for a 56 ford sedan with a 292/fordo and I will be running a 573 edelbrock 3x2. I want all the factory linkages, rods and brsckets. Then I'm guessing I will need to make a new rod that foes from the bellcrank to the carb progressive linkage.
Old 11-30-2013, 11:18 PM   #7
pepper1934
1956 ford car carb linkage call jack 925 998 5942 in calif
pepper1934 is offline   Reply With Quote
Thread Tools
Display Modes
