10-06-2019, 11:24 AM | #1 |
Rear main tube?
Is there a way to confirm the rear main tube is in place, without dropping the pan?
10-06-2019, 11:49 AM | #2 |
Re: Rear main tube?
None that I know of .
10-06-2019, 12:14 PM | #3 |
Re: Rear main tube?
I had one break off. I know this because I found the tube in the bottom of the oil pan when it was down and apart for other reasons.
I think if your rear main gasketing/cork is all in place and tight you probably would never know either. Joe K
Shudda kept the horse. |
10-06-2019, 12:28 PM | #4 |
Re: Rear main tube?
Maybe? You might be able to insert a bore scope camera thru the drain plug hole then carefully maneuver it towards the rear main bearing area. You can buy these small bore scope cameras for smart phones on EBay for under $10.00.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
10-06-2019, 04:08 PM | #5 |
Re: Rear main tube?
I agree, the scope camera is the only way that you will be able to look for the tube.
10-06-2019, 04:41 PM | #6 |
Re: Rear main tube?
Does it leak--? |
10-06-2019, 05:49 PM | #7 | |
Re: Rear main tube?
Trying to remember, is the tube visible under the pan tray or do you need to see above the tray? I would think a scope would be more maneuverable below the tray from the drain plug. |
10-06-2019, 07:44 PM | #8 |
Re: Rear main tube?
Pull the oil fill tube and run the scope in there. Don't have to lay on your back under the car nor drain the oil. Plus it is a bigger hole to work thru. Don't forget, there are the baffles that stick down so you would have to work under them from the bottom. Ok so I read the whole thing and missed Kirt in NJ's post of about the same thing Re the baffles.
I know the voices aren't real but damn they have some good ideas! Last edited by redmodelt; 10-08-2019 at 12:42 AM. |
