Old 10-26-2019, 07:04 AM   #1
30-9
Default 53 flathead
Trying to figure out a problem. Can someone explain what points do?
I recently put in new points gapped I think properly. But car is missing at higher rpms.
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 10-26-2019, 08:34 AM   #2
JWL
Default Re: 53 flathead
First, there is no possibility of a transformer(coil) working on straight DC. In order to make the coil work the DC has to be fluctuated-interrupted. During times of point closed operation the coil can absorb but not release until the current is interrupted at which time the absorbed energy is released from the coil and the cycle starts again when the points close. The rotor and cap are coordinated with the points in such a way as to direct the released energy to the appropriate sparkplug.
JWL is offline   Reply With Quote
Old 10-26-2019, 08:35 AM   #3
JSeery
JSeery's Avatar
The points are a switch, they start and stop the current flow through the coil.
Old 10-26-2019, 08:51 AM   #4
HD
use a dwell meter and see if the dwell changes when you give it the gas, if it does the bushing in the dist. is probably worn causing the shaft to wobble, also check the vacuum advance
HD is offline   Reply With Quote
Old 10-26-2019, 09:27 AM   #5
30-9
Ok not points
I took oilbath off thinking choke may not be fully closing it’s not that.
Gonna try shooting carb cleaner in carb
Thanks - 30-9
1939, 1940
Old 10-27-2019, 01:38 PM   #6
Phil Gillespie
Phil Gillespie's Avatar
Originally Posted by 30-9 View Post
Ok not points
Have you rechecked the timing? Incorrect timing will give these symptoms.
Also are you 6 or 12 v ? Spark plug leads and high tension leads breaking down under load may also give these symptoms.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 10-27-2019, 01:40 PM   #7
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
A defective condensor will do the same thing .....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
