03-30-2019, 07:53 AM | #1 |
Carb Maintenance
Do Zenith carbs tend to clog if they dry out from the engine not being run for a month or few months ? Is blowing out the jets and passages pretty much routine maintenance ?
03-30-2019, 08:28 AM | #2 |
Re: Carb Maintenance
I've never done it on mine in 10 years. I use only non-ethanol gas and run carb dry when stopping.
03-30-2019, 08:28 AM | #3 |
I would say NO. I see them run for years without attention. I personally don't care for the Zenith for a driver. I run Marvels which give better mileage and power as far as I can tell, and no stalling on hard turns or hard braking Jack
03-30-2019, 09:25 AM | #4 |
What is a Marvels?
03-30-2019, 09:42 AM | #5 |
My Zenith was pretty well clogged when I first resurrected my car. Even tho I run clean gas and run it dry at shutoff, every winter I take it off and look inside. It still will get some of that gummy residue in it. I just shoot some carb cleaner just to keep it cleaned out, so it's routine for me.
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 1979 MGB -Life's Too Short To Drive Boring Cars- |
03-30-2019, 10:21 AM | #6 |
03-30-2019, 11:25 AM | #7 |
for many years I did nothing, then I was finding a collection of goo on the tips of the jets after sitting, now I shut off the fuel and run the bowl dry,cured that problem, about once a year I drop the lower bowl (one of the best features, so easy to do, just one bolt), slosh the fuel around and dump it into a can----along with cleaning the fuel bowl screen
03-30-2019, 11:49 AM | #8 |
Miss read question.
03-30-2019, 11:49 AM | #9 |
Don't do anything with mine, use ethanol gas, and have never had an issue.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
03-30-2019, 02:46 PM | #10 | |
It's not that big a deal to drop the bottom half of the carb, spray through the jets from the tip with some carb cleaner, shake the excess fluid out and bolt the bottom of the carb back. Maybe 5 minutes work. If it ides really poorly, you need to pull that jet from the upper half and clean it. I will go for months and not have a problem, then all of a sudden the car runs poorly when I start it after sitting. I clean the carb and it's back to normal. Henry was a genius to have the Zenith carb held together with one bolt!
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
03-30-2019, 03:00 PM | #11 | |
03-30-2019, 04:10 PM | #12 | |
The other side of the engine compartment is almost empty... I wonder what percent of all Model A's were built with RHD?
03-31-2019, 06:41 AM | #13 |
If I think the car may be sitting for a period I just run it dry. There is not too much to maintain on a carburetor. If they develop a problem, they are not hard to fix.
