08-08-2015, 07:41 PM | #1 |
Rear hub bearing seal
On the eve of destruction. Ordered new drums, with hubs, seals and snap rings. Plan on using the old, good bearings.
Having a time getting the seal out of the old hubs. Prying, punching; nothing working, yet. Yes, the snap ring is removed. Read about dropping the hub from 2 feet and letting the bearing force the seal out. Have dropped it from 6 feet, repeatedly - didn't budge. Tomorrow is another day. The Dremel with a cutting disc may be my answer! |
08-08-2015, 09:19 PM | #2 |
Re: Rear hub bearing seal
I've used a large pry bar to pop them out, or a large screwdriver might also work.
When you install the new ones, be sure to tap them down only far enough for the snap ring to fit in the groove. |
08-08-2015, 09:22 PM | #3 |
I have used the stub of an old axle shaft stuck down into the taper this give's your pry bar something to lever against.
08-08-2015, 10:41 PM | #4 |
I have dropped a large socket into the hub and used a rolling head pry bar to lever it out.
A's Always Dave |
08-09-2015, 06:44 AM | #5 |
i take an ice pick to make a small hole in the metal clad of the seal.. then slap it out using a small slide hammer with a sheet metal screw on the end
08-09-2015, 07:03 AM | #6 | |||
Thanks for the caution concerning the new seal installation. Last edited by bunnyc; 08-09-2015 at 07:11 AM. |
08-09-2015, 07:22 AM | #7 |
then collapse the side of the seal a little with a screwdriver or small flat chisel using the hole you made with the pick..
then retry with a new hole and a decent size screw these methods work for me youll get it one way or the other the suppliers do sell a seal install tool that sets it at the correct depth FYI.. |
08-09-2015, 08:59 AM | #8 |
08-09-2015, 12:21 PM | #9 |
Seals are out! Only casualty, one chip in my nail polish.
08-09-2015, 12:32 PM | #10 |
(Seals are out! Only casualty, one chip in my nail polish.[/QUOTE])
That's funny! We always think of the guys working on model "A"s. Recently on the MAFCA tour in Maine there were quite a few ladies driving the A's. Keep up the good work--- Al |
08-09-2015, 12:50 PM | #11 |
I do the drop trick often. You can't just drop it, put a little oomph behind it! Tales more then one good drop for them to pop out. Use card board (if you haven't cleaned them) on a piece of plywood on cement floor.
08-09-2015, 05:12 PM | #12 |
There was a post several years ago by Tom Wesenberg or Tom Endy ??. He used a cut off axle stub as a fulcrum and a "Cats Paw" (carpenters tool) ($12 at Home Depot). It works quickly and is worth having because it will be used again by yourself or someone else.
Vic |
08-09-2015, 05:40 PM | #13 |
This is what I used. I had the hub in a vise and was pulling on the long end. Arm strength and body weight didn't get it.
Decided to pound on the long end with a BFH. That did it! |
