Old 09-28-2020, 05:35 PM   #1
imacrazy
Default torque Specs
Where do you find find the model a ford torque specs?
Thanks in advance.
Bill
imacrazy is offline   Reply With Quote
Old 09-28-2020, 07:12 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: torque Specs
Ford never published any torque specs for nuts and bolts on the Model A.
A torque wrench was not in use in 1928-31; the first patent for one was filed in 1931.
Ford relied on the experienced hands of the mechanic to know when something was "tight enough" but not too tight as to break the bolt, stud, etc.
I have seen published torque numbers in Les Andrews' "Model A Mechanics Handbook" and I think in the Brattons parts catalog. Those are a good guide.
Jim Cannon
"Have a Model A day!"
Old 09-28-2020, 07:23 PM   #3
PalAl
PalAl's Avatar
Thanks in advance.
Bill
Is this what your looking for?
PalAl is offline   Reply With Quote
Old 09-29-2020, 07:36 AM   #4
30 Closed Cab PU
If using Les Andrews be aware that the Oil Pan Bolts and Manifolds are speced way high than what should be used. There may be others.
Old 09-29-2020, 10:01 AM   #5
imacrazy
Thanks PALAL that was what I was looking for. Have a good day and stay safe.
Bill
Old 09-29-2020, 03:37 PM   #6
PalAl
PalAl's Avatar
Bill
Welcome........ Glad I could help
Old 09-29-2020, 04:29 PM   #7
dlfrisch
dlfrisch's Avatar
I also sourced for torque listing information....Barton’s has the above page
dlfrisch is offline   Reply With Quote
