05-28-2012, 10:23 PM | #1 |
Clutch - for what?
I purchased this clutch at a swap meet in February. I was told it was for an "A" and it sure looked like it until I gat it home and found out that the spline is too small. It is a 10 tooth spline like the "A" but the diameter of the sline would be 1.062" diameter instead of 1.375 like the "A". There are some part numbers but I can't make out what they are. (See Picture.) The outside diameter is 9" like the "A" but the length thru the hub is 1" rather than 1.375 like the "A". Does anyone know what this is for? Thanks for any help. Don/WI Pictures did not load. I'll try again.
05-28-2012, 11:14 PM | #2 |
Re: Clutch - for what?
05-29-2012, 05:44 AM | #3 |
From the part number, I would say it is from a 1966 Ford truck.
05-29-2012, 06:53 AM | #4 |
Might be for and A. Cant tell fromn the small pix, but, A F150 Overdrive conversion like I build uses a 1.062 dia x 10 spline clutch disc.
05-29-2012, 10:22 PM | #5 |
I have an f-150 overdrive in my 31 sw . Had the engine out to solve a rear main oil leak so decided to install a lightened fly wheel and v8 clutch dic and pressure plate . I do not know the specs on the clutch disc that was put in . Will any other clutch disc other than the one you described fit . I do know that when the tran is in nuetral and the engine running there is a rattling noise coming from the bell housing . You push in on the clutch and the noise goes away . Thanks |
