04-11-2019, 06:34 PM | #1 |
Removing Ign. Lock Cylinder 1940
Does anybody know the "secret" on removing the ignition lock cylinder on a 40? I can't get it to turn anymore and it's in the lock position. I have a new lock cylinder from Drake to replace it.
04-11-2019, 07:29 PM | #2 |
Re: Removing Ign. Lock Cylinder 1940
Look on the under side below the lock cyl and you should see a pin drill a small hole and tap it and a small slide hammer can be used to extract the pin. Then the lock cyl can be removed. Personally, I would not go to all this trouble for a Bob Drake replacement, NOS ones still show up.
04-11-2019, 07:42 PM | #3 |
or send your old one to phil the lock guy here. could be nothing wrong with the lock, just the other parts are sticky or frozen. doesnt the cylinder have to be unlocked to slide out? i forget
04-11-2019, 07:45 PM | #4 |
Have you tried squirting something like WD 40 into the slot. This worked for me on an outside door lock
04-11-2019, 07:58 PM | #5 |
All three of the previous posts have offered great advice.
Once you have removed that pin, I'd suggest you drill the hole out and tap it for a 5/16" - 24 tapered set screw.
04-11-2019, 08:01 PM | #6 |
04-11-2019, 08:06 PM | #7 | |
Finally, drill and tap for a 5/16" - 24 set screw (.272" drill bit). By the way, WD-40 is not really a lubricant. It kind of acts like one for a short time.
04-11-2019, 09:07 PM | #8 |
drill the small holding pin on the under side of the cylinder then screw a sheet metal screw in the slot where the key goes pull out cylinder with a vice grip when cyl is removed drill the holding pin hole out & tap it to accept a grub screw
04-12-2019, 07:08 AM | #9 | |
04-12-2019, 12:10 PM | #10 |
You can try to drill it out, but if the drill gets off center you can create yourself a mess. The cost of a cheap slide hammer is cheaper than the potential of ruining a good ignition lock.
04-12-2019, 09:50 PM | #11 |
If you look for a NOS ass'y, check pics very closely. I bought one for my '41 and it fit fine except the set screw indent was 90 deg. off. Also even if the cylinder looks/ listed as correct, the tab inside that unlocks the column may be wrong
