04-06-2019, 06:11 PM | #1 |
Correct Steering Wheel Colors For 40 Wagon
Does anybody know the correct steering wheel colors for the 40 Deluxe wagon? I need to restore mine to original. The center color is brown but the rim is a dark color with a lighter color underneath that is close to the Rose color on the dash. The exterior color is Yosemite green. Thanks!
04-07-2019, 03:24 PM | #2 |
Re: Correct Steering Wheel Colors For 40 Wagon
The attached photograph will show you how the wheel should be painted. The two colors should match your dash colors.
I have the formula's that I use and believe them to be quite accurate. However, if you are attempting to match your dash, you'll probably be best served to have those colors professionally matched.
04-07-2019, 06:57 PM | #3 |
Thread Tools | |
Display Modes | |
