06-26-2013, 02:52 PM | #1 |
Model B hot start problem
Here in the UK with a 1932 Model B 24hp fitted with Zenith carburettor
recently and beautifully rebuilt by Dave Renner. Cold start procedure as thus: Ignition on; GAV valve 1.5 turns open and full choke. Choke in and GAV valve almost returned to fully closed whilst warming up. Starts immediately.When warm runs perfectly and idles faultlessly. Turn off ignition. Give it two minutes; pull the starter and fires immediately. Leave it for ten minutes and will not start without choke. Engine and ignition timing correct. Contact breaker gap correct as are spark plugs. Coil and condenser appear to be ok. Any clues and apologies for Limey spelling of CARBURETOR ! ? |
06-26-2013, 03:04 PM | #2 |
Re: Model B hot start problem
My shot at this: You of course cannot prime by giving the thing a stomp on the pedal because you do not have a conventional accelerator pump. The thing can only draw gas for starting by your air flow pulling it in as on a running motor, and you aren't getting enough flow to accomplish that. Higher float level MIGHT allow the thing to feed at extremely low RPM, but it really isn't meant to do that...on a pumpless carb needing a very brief choke application when warm is not abnormal. I suspect that (and also the existence of the GAV for when it has started) is why A and B Fords have a spring loaded choke well suited to very brief use rather than the more common sort that stays where you pull it.
Now, if you want some trouble...I bought my B pickup from a guy who displayed it at a show corral for 2 days before I came along, with hundreds of people crawling through the cab and fiddling with everything. When delivered, the formerly great running truck had to be restarted about 15 times to stagger from its trailer into my garage...investigation eventually showed that some happy show patron had turned the GAV enough out that the needle valve dropped free! |
06-26-2013, 10:20 PM | #3 |
On my B, I never turn the choke cable. Turning it eventually will break the cable. I leave it turned in all the way in .....not tight.... just in. I pull the choke closed to start the engine. After a few turns I release the choke and it usually starts ....then I pull the choke almost closed and hold it there for a few seconds until the engine starts to smooth out. As it warms up I gradually release the choke until it runs smooth without any choke. Usually starts right back up with no choke when warm. Needs the choke again if it has cooled some. This method is more "hands on" but it spares the choke cable undue stress. I know they were designed to twist but nothing lasts forever and they are really tough to find unbroken.
Early Ford Lock & Key Service https://www.fordbarn.com/forum/showthread.php?t=46583 |
06-27-2013, 01:34 AM | #4 |
Dear Bruce and Phil; thanks for the advice. Phil; you say you never turn the choke cable? The GAV valve is operated by the choke cable and I need to open the valve a little to start the car? Is my cold starting procedure incorrect?
06-27-2013, 07:30 AM | #5 |
Don't forget this is an updraft carb. If it takes a little choke to start as long as it starts right up I don't see a problem. G.M.
www.fordcollector.com |
06-27-2013, 10:17 AM | #6 |
06-29-2013, 04:41 PM | #7 |
OUCH ! Problem now seems to have got even worse. After turning off ignition after a run engine refuses to start even with choke? Wait for say 20 minutes for things to cool down a bit and then will start using cold start procedure.
Any clues? |
06-29-2013, 06:33 PM | #8 |
Condenser??
Paul in CT |
06-30-2013, 12:45 AM | #9 |
On my B dist,I have a spare condenser screwed onto side of dist & it is only a matter of unhooking one & then hooking up the other.As already stated,the choke cable is meant to be turned,just as in a model A.
06-30-2013, 02:54 AM | #10 |
Thanks. I'll try the condenser. Is the coil likely to be giving up when warming up?
06-30-2013, 07:40 AM | #11 |
My money is on a bad coil. Walt
