06-23-2013, 05:48 AM | #1 |
Clutch pedal not returning
Hi guy's, had my 36 Fordor out today to give it a run and it started fine and got through the town traffic fine as I drove out to a friends farm just out of town (10miles or so)
Anyway on my way back in the first time I changed down the clutch pedal didn't come all the way up so I used the top of my foot to flick it up. After several gear changes on my way home the same thing (just kept flicking it backup) So I made it home, the clutch didn't slip and as I was double clutching the gears didn't grind, so what the heck is going on:confuse d: How do I get the pedal back to where it should be, and just to clarify the situation the clutch pedal is only coming back up about half way. Any and all advice will be most welcome Mick |
06-23-2013, 05:59 AM | #2 |
Re: Clutch pedal not returning
Check to see if your return spring is broke. Marv
06-23-2013, 07:20 AM | #3 |
Check the hole in the wood floorboard to make sure nothing is rubbing against the pedal.
06-30-2013, 01:20 AM | #4 |
Re: Clutch pedal not returning / Problem now worse
Well finally got under the car and the spring looked fine, greased the pivot points and thought it might "free up" driving. Got the car out and went for a drive, steered it up the two biggest hills in town and the clutch seemed fine (no slipping etc) but two blocks from home I pushed it in to downshift and the clutch pedal stayed on the floor
Managed to limp it home in first gear, will be a couple of weeks until I can look at it again (I travel for work). So just to recap. The pedal started by not returning fully but the clutch seemed fine Checked spring return and greased the pivot points Test driving up BIG hills, no slipping clutch Two blocks from home pedal stays on floor Again guys any advice most welcome Mick |
06-30-2013, 05:56 AM | #5 |
Sounds as if the three fingers for the pressure plate are not returning to their proper position. When this happens is there a lot of free pedal travel? You may want to remove the inspection cover and see whats happening.
06-30-2013, 07:22 AM | #6 | |
Have you experienced this problem or seen it before? Mick |
06-30-2013, 08:53 AM | #7 |
Is the spring on the t/out brg there?? Is there a clutch pedal return spring??
Is the clutch actuating arm broken (outside of tranny, clutch pedal linkage connects to this)? Is it possible the "pin" holding the t/out brg release arm (inside the tranny) has sheared?? Paul in CT |
06-30-2013, 09:48 AM | #8 |
I just used a pressure plate where the fingers did not move correctly by cleaning the finger pivot pins with penetrating oil, then cleaning with brake cleaner and finally lube with a drop of very good 10W oil. After cleaning the fingers moved freely. There was a lot of dirt and light rust. but this was found before the pressure plate and clutch were installed. It is possible you have other damage that could prevent the pressure plate fingers from reseting such as broken spring in the pressure plate or pivot pins that are coming out.
When you adjust the free travel of the clutch pedal you want about 3/4 to 1-1/4 inch of pedal travel before the throwout bearing contacts the pressure plate fingers. The important thing is the adjustment keeps the throwout bearing away from the pressure plate fingers, even at high engine RPM when the pressure plate weights exert their force against the clutch plate. If you had a sudden change in how the clutch and transmission reacted together this could be a sign of problems where as with changes over time an adjustment could be the answer. |
06-30-2013, 09:50 AM | #9 |
The throughout bearing may be binding on the trans where it moves back and forth. I am sure you can lube it by taking the V8 cover off the trans. If this does not work i guess you will be taking the pressure plate out.
07-01-2013, 01:41 AM | #10 | |
Mick |
