12-25-2019, 11:51 AM | #1 |
TransmissionThrow-Out Bearing Lub.
Is there a better way to lubricate this bearing without having to remove floor mates/plate? I'm thinking of tubing running from the alimate to an easier location anywhere else. Hip-arthris is my problem. Suggestions Plz
Thanks |
12-25-2019, 12:46 PM | #2 |
Re: TransmissionThrow-Out Bearing Lub.
TO bearings are sealed so don't need to be lubed. The stock hose just lubed the collar, and rarely needs any grease, if ever.
12-25-2019, 01:19 PM | #3 |
Not being cheeky, why then the grease fitting? I am relatively new to
Model A's, I have on occasion removed the floor boards to grease the throw -out bearing. Gerry Birch Bay WA MERRY CHRISTMAS |
12-25-2019, 01:20 PM | #4 | |
Damn! I've been lubricating every alimate in sight, no matter where (except water pump) every 500 Miles. What a relief this is Thanks Jim |
12-25-2019, 02:07 PM | #5 |
The original release bearings were greaseable thru that fitting along with the collar.
Most replacement bearings are sealed and repro collars don't provide for lube to the bearing. I haven't tried to see if the bearing could be greased with a needle or by removing a seal. I got caught in the Timken bearing no/low grease issue of a decade or so ago, having to change/replace too many. So I'm pretty paranoid and now try to hand lube before installation. |
12-26-2019, 01:17 PM | #6 |
12-26-2019, 01:24 PM | #7 | |
Thanks Jim -- my real problem is that I don't know what I don't know. Thought I was supposed to lubricate every greese fitting in sight -- but got a lesson with the water pump. Thanks |
12-27-2019, 02:33 PM | #8 |
Lube chart (P/N 99053) says Throw Out bearing every 2000 miles!
12-27-2019, 02:56 PM | #9 |
Wait, If you are using the Original 1928 Multi Disc Clutch set up, the Nice Bearing Co. & the Ford Script one does have a fitting to lube it..
12-27-2019, 02:58 PM | #10 |
Lube chart was written 90 years ago. The new bearings are sealed. If you insist on squirt lube in the fitting, use very little. As already mentioned, all you are lubing is the hub where it rides on the transmission snout.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 12-27-2019 at 03:03 PM. |
12-27-2019, 03:00 PM | #11 | |
Yes that was my point. If 2000 miles was good in 1928 then 500 miles is over kill for a sealed bearing. I just give it a little to lube the hub. Last edited by Benson; 12-27-2019 at 04:03 PM. |
12-27-2019, 05:54 PM | #12 |
Ford tried using a grease cup lube fitting for the to bearing in 1932 but it didn't work well enough to continue it in production.
12-27-2019, 07:01 PM | #13 |
Thanks for the explanation because I sure wouldn't have got that from your statement.
The Master Cylinder Enjoying life at the beach in SoCal... |
12-28-2019, 09:30 AM | #14 |
When you pull the transmission be sure to check the throw out bearing.
If it is stamped "Aetna" ... these are famous for going bad. As I remember they "seize up" when bearing gets warm. Many of these junk bearings still show up at swap meets, on Ebay, Craig's list and Amazon. It seems that not everyone knows about the problem or they know and are crooked enough to resell them! Just saying ... |
12-28-2019, 11:22 AM | #15 |
Aetna, well that's good to know. Thanks.
12-28-2019, 11:58 AM | #16 | |
12-29-2019, 12:43 PM | #17 |
