04-30-2017, 08:55 PM | #1 |
French flathead block
Hi just wanted to get some feedback on the French blocks , this one still has the governer hole I guess that's what it is in the back , the one I see on eBay doesn't have that it all smooth like the opposite side , please any feed back appreciated
04-30-2017, 09:07 PM | #2 |
Re: French flathead block
The one on ebay has had the governor mount machined. You can get them in the original form or for more money, machined.
04-30-2017, 09:16 PM | #3 |
I bought the cheaper one with the governor provision and did the machine work locally. After I plugged the extra holes I cleaned up the few blemishes with JB Weld, sanded it down and primed it, looked just like the one in the picture from SFFH.
04-30-2017, 10:21 PM | #4 |
The beauty of these blocks is: You can run a distributor from this hole. So I'm told. Wouldn't that confuse a few people. Be great for a dual plug head.
05-01-2017, 08:58 AM | #5 |
I know 4 différents cast for french blocks .
05-01-2017, 09:48 PM | #6 |
10-11-2017, 06:38 PM | #7 |
Just picked up a new French block and I was wondering if anyone has any pictures of what you find when you start removing the rear mount for the governor.
10-11-2017, 06:50 PM | #8 |
Go slow with the grinder. I can't remember but I think I plugged 2 holes with pipe plugs and smoothed it off with JB weld. My memory's a little fuzzy on that
10-11-2017, 06:57 PM | #9 |
Thanks!! I will....
10-12-2017, 07:37 PM | #10 |
Had a French block built for my 40 coupe and although it was close, there was no interference with the governor location being left alone. Gas pedal arm is right there but cleared fine. I left it alone and plugged the holes. I will have to look at my other block and see if it's there - that one may end up in my roadster w/4" crank, 080 over and an L100 cam ....
10-12-2017, 07:55 PM | #11 |
I'm pretty sure I had a ride in the 40. is that still on the road?
10-12-2017, 08:11 PM | #12 |
I really like this idea. For a competition car, anyway. Seems that there would be firewall clearance problems with anything else.
10-13-2017, 12:48 PM | #13 |
The Ford Cologne G29T engines had a distributor on the back if I remember correctly but I don't know how much similarity the SUMB engines have to it.
10-13-2017, 02:04 PM | #14 |
Here's a koln G29T engine with dizzy on the back.....well bugger me!...until you mentioned it I never knew of such a thing. You never stop learning new stuff about flatheads..wow.
GB https://www.youtube.com/watch?v=bRiNFzL4epM
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
10-13-2017, 07:18 PM | #15 |
Some bondo or epoxy is needed to make the rear of the block look more like the Ford once the govener has been cut away. A trained eye will still know its not a Ford casting after the surgery.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
10-13-2017, 08:33 PM | #16 |
Yes you did but it is now with a new owner - sold it about 1 1/2 years ago.
