10-21-2017, 12:21 PM | #21 |
Re: The Mystery of the Right Side Spare Tire on my 1930 PU?
I'm not sure there is a question or statement here. I did base my observations on 42 years of vintage car and aircraft experience, both restoration and preservation of many different brands.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
10-21-2017, 12:26 PM | #22 |
I agree. I grew up in Dearborn and I toured the plant when my father worked for Ford as a research scientist. I used to walk past the Ford test track when walking to school.
10-21-2017, 12:34 PM | #23 | |
Based on research by Steve Plucker, and my brief contact with him, the marking on the cross member did not indicate anything conclusive.
10-21-2017, 12:37 PM | #24 |
In the absence of facts assumptions are the educated mans way to come to a conclusion. Often in forums like these assumptions foster conversation and drive the question closer to fact.For instance, the riveting of the side mount bracket is an interesting direction of the evidence..Ford used riveting in a number of production applications, though it wouldn't be a surprise if the dealerships employed rivets as well, it was a common means of fastening structural components back then.
10-21-2017, 12:46 PM | #25 |
is that a whizzer leaning against the wall?
10-21-2017, 01:09 PM | #26 |
10-21-2017, 04:39 PM | #27 |
Yep
Its a 1949 Schwinn WZ-507 with a Whizzer model J. Badged as, assembled by, and sold through, a B.F. Goodrich retail store. All original, runs great. Too fast for a bicycle!
10-21-2017, 07:44 PM | #28 |
I have a late 1931 closed cab steel roof wide body that came to me with both left and right side mounts. Both sides have support brackets that are bolted and appear identical. It has the indented firewall. Any ideas on that combo? Mike in Maine
10-21-2017, 08:34 PM | #29 | |
Pickups ordinarily came with just one side-mount, usually the on the left. AFAIK, factory-installed ones were riveted. A lot could have happened in the last 86 years. My guess is the factory-riveted arm was replaced with a bolt-on for some reason (collision damage?) Installing a second side-mount where there was none before requires some work but it can be, and has been, done. |
10-21-2017, 09:09 PM | #30 |
FYI & FWIW
The Brake Rod return springs on your vehicle are the wire type and they were used from July 1931 through the end of production. See the attached RG&JS 7-8 REVISED 2011
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
10-21-2017, 09:33 PM | #31 |
True, but there is no indented firewall, so it would probably be earlier than that. Also, to the best of my understanding, only wire type return springs were supplied by dealers as later replacements.
10-21-2017, 09:36 PM | #32 | |
10-21-2017, 10:09 PM | #33 |
10-22-2017, 08:13 AM | #34 |
Folks "think" California Cars are "RUST FREE"---Just hang around the COAST & OBSERVE!!!
Bill Notrusty
10-22-2017, 09:18 AM | #35 | |
10-22-2017, 09:19 AM | #36 | |
1. the rusty coast 2. the solid desert 3. the mostly solid valley (marine inversion, tule fog) 4. the solid foothills (no marine inversion, dry) 5, the rusty mountains (no salt, but just as wet as the coast) he's a strange one in other ways too ,a mountain of hoarded parts, wont pass a screw.. |
10-22-2017, 12:12 PM | #37 | |
Fortunately my pickup lived (almost?) all of its life near Fullerton CA (as I was told anyway). Fullerton is about 15 miles from the coast and it's dry most of the time. "...he's a strange one...wont pass a screw." No comment.
