09-22-2018, 08:46 AM | #1 |
Evaporust/rust 911
When using evaporust or rust 911 can it be sprayed like paint on large pieces? Once a part has been subject to these products, what has to be done to lay a coat of primer on the part? Does it have to be washed in water first? Any help is appreciated. Thanks. Jack
09-22-2018, 09:33 AM | #2 |
Re: Evaporust/rust 911
I doubt spraying will work. I always immerse my parts in it and let it soak. Rinse with clear water.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
09-22-2018, 01:28 PM | #3 |
Chris;; soaking is the best way to use the evapo rust but how do you do a frame with this product? Jack
09-22-2018, 03:50 PM | #4 |
09-22-2018, 08:59 PM | #5 | |
But seconded on sandblasting. -Tim
No one wants advice - only corroboration. -John Steinbeck |
09-22-2018, 09:11 PM | #6 |
09-22-2018, 09:27 PM | #7 |
Jack. I have a 57 olds 98 and the hood is punched full of louvers. A really nice hood but some what rusty on the in side. Did not want to sand blast i with all those louvers. So i taped up the outside with plastic sheet and duct tape. Flipped it over and made a large batch of 911 mixed. And made a lake in side up to the edges. After a couple of days it looked like brand new clean metal. Drained it, rinsed it with clean water and painted a good coat of epoxy primer. If you can soak the part it would be best. I am not sure spraying it on would work that good. Soaking is the best in my opinion.
09-22-2018, 10:32 PM | #8 |
09-22-2018, 10:35 PM | #9 | |
I've seen that done.
