10-30-2019, 12:12 PM | #21 |
Re: Champion 3xs or other plugs?
The W sixteen Y Spark plug is hotter at fifty five hundred RPM .
Fifty five hundred RPM doesn't apply to a stock or near stock model A engine The model A engine produces maximum horse power at twenty two hundred RPM Unless the engine is highly modified it will never reach fifty five hundred RPM . I believe that the article stated that the Champion W sixteen Y spark plug was closer to W fourteen . The Champion W fourteen is WAY TOO cold for the model A engine and would run black all of the time . The article also states that the original Champion Three X is about the same heat range as the Champion W eighteen . The projected tip on the Champion W sixteen Y caused me to buy two boxes of ten , W sixteen Y spark plugs After nearly sixty years of working on my cars I do know that a projected tip means hotter heat range . I did not know that the heat range of the W sixteen Y spark plug was determined at fifty five hundred RPM . Just to make this easier to understand , the W sixteen Y spark plug is much colder at twenty two hundred RPM and is too cold for the model A !!!!!!! A local parts house happened to have two boxes of ten , W sixteen spark plugs Thinking that the W sixteen would be hotter I bought both boxes . It didn't take very long to run through the two boxes of too cold spark plugs . This SHOULD tell a person that the Champion W sixteen Y is just too cold and will run black . This has also been my experience . Last edited by Purdy Swoft; 10-30-2019 at 12:23 PM. |
10-30-2019, 12:38 PM | #22 |
I used W16Y for 20 years ... short story is:
In the 60's we lived 25 miles one way from town and I drove it 7 days a week at 55 MPH and around town then back home. Engine speed never got to much more than 2800. 45000 miles during this time ... At highway speeds W16Y plugs worked great! Then we moved to town with many short trips (5 to 10 miles or so), with stops in between and little highway. W16Y Plugs started to foul out. Installed W18s which work well. Last edited by Benson; 10-30-2019 at 02:47 PM. |
10-30-2019, 01:06 PM | #23 |
I also used the W sixteen Y spark plugs for many years .
They ran black most of the time . At the time I didn't know that the advertised heat range of the W sixteen Y spark plug was determined at fifty five hundred RPM . If I had driven the model A faster it may have run cleaner eaner . Last edited by Purdy Swoft; 10-31-2019 at 02:40 PM. |
10-30-2019, 01:08 PM | #24 |
10-30-2019, 03:31 PM | #25 |
I ran the W18's for years with NO problems. FWIW
Paul in CT |
10-30-2019, 06:20 PM | #26 |
10-30-2019, 06:52 PM | #27 |
10-30-2019, 07:41 PM | #28 |
Folks, went to my local NAPA dealer and he suggested I try Auto Lite 3076. I looked at a cross reference chart and the 3076 spark plugs were comparable to the W18.
Any comments ............... please I am new to Model A's make this a teachable moment ie benefits of one verses the other Gerry Birch Bay WA |
10-31-2019, 05:35 AM | #29 | |
Did you look at #8. |
10-31-2019, 09:15 AM | #30 |
Pat, please explain #8, is that an Auto Lite plug that would be more comparable to the W18 than the others?????
10-31-2019, 10:31 AM | #31 |
Did not feel like rereading this 30 post string, so excuse me if this has previously been covered. The following was my expereience. I was running the 3076. For some reason that I have yet to figure out my truck seems to run rich and the 3076 would run black on the center insulator, especially around town. Switched to the Champion W18, now the center is tan with a little black flecks. The W18 seems to be a little hotter than the 3076. So what you need depends on your plug reads.
Plug reads, only use the center insulator for the reads, the rest of the plug typically will look black. However if the rest of the plug is wet, oily, of has a lot of black fluffy soot, you have an issue. Plug selection may not solve the issue. If you do a search here there is probably a lot of info on plug reads. |
10-31-2019, 10:35 AM | #32 | |
Patrick, I seen some Autolite 3076 plugs on eBay https://www.ebay.com/itm/Spark-Plug-...-/201694271952 if you are interested? Last edited by Y-Blockhead; 10-31-2019 at 10:43 AM. |
10-31-2019, 12:21 PM | #33 |
Thank you read post #8 ;~))))) and the other regarding 3076 verses W18. Will try W18.
10-31-2019, 01:12 PM | #34 |
11-01-2019, 11:28 AM | #35 | |
Thanks, but. 3076 are readily available. 3077, which I prefer, don't seem to be. |
02-03-2020, 08:23 PM | #36 |
I have four like new W-20 Champion spark plugs .Are they close to the Champion 3 X plugs in heat range and are they a good plug to use in a stock engine that is probably in need of a rebuild or at least new rings and a valve job.
"Never complain,never explain"... Henry Ford II |
