Old 10-07-2019, 02:21 PM   #1
Jake's 40
Default stubborn rear brake drum seal removal
took a few tries, but eventually I won the day. for some odd reason the fronts were not an issue.
attempting to simply pry with a long screwdriver only deformed the side wall of the seal. needle nose vice grips just took a bite out of the wall of the seal.
Jake's 40 is offline   Reply With Quote
Old 10-07-2019, 02:23 PM   #2
Jake's 40
Default Re: stubborn rear brake drum seal removal
hmmm... OK, let's drill a small hole & see if I can pry it out with a punch / drift.
no joy.
Old 10-07-2019, 02:25 PM   #3
Jake's 40
it was suggested to simply drop the drum on the pavement. (the weight of the bearing would do the trick ?)
did a good job of shredding the paper.
Old 10-07-2019, 02:39 PM   #4
Jake's 40
full jaw vice grips. drive the lower jaw into the seal as far as possible. lock the jaws and whack the end of the vice grips several times.
for the second drum I'll buffer the vice grips with a piece of thick leather at the edge of the seal opening. I did deform the channel for the snap ring slightly. I oriented the void in the snap ring to this area.
it's 5:00 somewhere
Old 10-07-2019, 03:11 PM   #5
Kube
Kube's Avatar
it's 5:00 somewhere
Jake, You can purchase a seal removal tool that makes this job a snap.
"Imagination is a crutch used by those who lack knowledge and intelligence ."
B
. Franklin
Old 10-07-2019, 05:20 PM   #6
philipswanson
Yes, use the right tool for the right job. Any auto parts store has them. They are a hook that snags them on the back side allowing you to pry them up.
philipswanson is offline   Reply With Quote
Old 10-08-2019, 04:33 AM   #7
Fairview
And I picked up a helpful hint here on the forum:
To drive in the new seal, assuming you don’t have a seal driver kit, a short pvc pipe connector (2 inch inside diameter 92 cents at Home Depot), is the perfect size to evenly tap the seal in. Just get it lined up and carefully use your hammer. Works like a charm.
Fairview is offline   Reply With Quote
Old 10-08-2019, 02:21 PM   #8
19Fordy
19Fordy's Avatar
Gee, To remove the seal I just inserted a long,thin tapered drift punch and tapped it out.
Old 10-08-2019, 03:41 PM   #9
marko39
On my 39 I used two small screwdrivers to pry it out. You have to be careful not to distort it.
marko39 is offline   Reply With Quote
Old 10-10-2019, 07:17 AM   #10
JM 35 Sedan
JM 35 Sedan's Avatar
You can easily do that on front drum/hubs, but not so easily done on the rear drum/hubs from 32 to 48, IMHO.
John
